picture is worth a thousand words
aireupora(at)sbcglobal.ne
PostPosted: Mon Jun 01, 2009 4:11 pm    Post subject: picture is worth a thousand words Reply with quote
I started to install my brake line and got as far as the 15" from center on the gear box/baggage bulkhead. I'm supose to drill a 1" hole in the aft bulkhead then a 1" hole in the fuselage. I have the X shaped tri-gear wooden frames in the baggage/gear box. 'When I place my speed fairing I'm about four inches behind the landing gear. It looks like I need to drill two holes through the wood frame to get in front of the landing gear. Before I drill am asking is there a better way?
Rick Stockton
A210
