CDE2fly(at)aol.com Guest
Posted: Sat May 30, 2009 11:05 am Post subject: 912S External Alternator Question |
Just completed the first start on a 912S and all went well except the Rotax external 40 amp alternator is not providing any power (I have the internal alternator from the engine switched off while checking the external alternator). I currently just run a wire from the output stud on the alternator to the power buss. I'm thinking that I also need to run a wire from the faston connection on the rear of the alternator to the postive battery post. I believe this is how the alternator senses low voltage in the battery and allows the regulator to send power to the alternator out put stud. Can any one confirm?
Thanks!
Chris
Kitfox 7 (99% Complete)
Rotax 912S
A Good Credit Score is0x1201367186/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=MaystepsfooterNO62>See yours in just 2 easy steps!
lcfitt(at)sbcglobal.net Guest
Posted: Sun May 31, 2009 8:54 am Post subject: 912S External Alternator Question |
Chris,
I am definitely not an expert on alternators, but it is my understanding
that if you simply switch the internal "alternator" turned off without some
load across the output leads of the regulator, you can fry the regulator.
If it is swithched off between the coils and the regulator - no problem.
Others with more understanding will no doubt chime in, but a true alternator
needs voltage from the battery to energise the field winding, otherwise all
you have is a bunch of wires spinning.
Lowell
Posted: Sun May 31, 2009 6:44 pm Post subject: 912S External Alternator Question |
Thanks for the advice Lowell. I'll rearrange things to send the internal amp power to the switch first then to the regulator. I think you're right about the alternator needing voltage the battery. I'll check with Lockwood tomorrow and
In a message dated 5/31/2009 12:54:57 P.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
| Quote: | --> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Chris,
Lowell
----- Original Message -----
Sent: Saturday, May 30, 2009 11:59 AM
Subject: 912S External Alternator Question
| Quote: | Just completed the first start on a 912S and all went well except the
Rotax
alternator
post.
Can
any one confirm?
Thanks!
Chris
Rotax 912S
**************A Good Credit Score is 700 or Above. See yours in just 2
easy
steps!
MaystepsfooterNO62)
======================== the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
Float Flyr
Posted: Mon Jun 01, 2009 7:49 am Post subject: 912S External Alternator Question |
That all depends on whether you alternator has field coils or a permanent magnet. The one with the field coils the voltage regulator adjusts the power going to the field coils thus adjusting the voltage of the alternator output. The permanent magnet alternator tries to produce as much power as it possibly can. The –power produced is then sent to a circuit which directly regulates or stabilizes the power produced.
Generally the field coil alternators produce DC because the rectifier plates are built into the alternator itself. The permanent magnet types I’ve seen do not have the rectifier plates built in. Rectification ( changing from AC to DC) is done after voltage stabilization.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of CDE2fly(at)aol.com
Sent: 01 June 2009 12:02 AM
Subject: Re: 912S External Alternator Question
Chris,
Lowell
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
