sarg314(at)gmail.com Guest
Posted: Tue Jun 02, 2009 6:16 am Post subject: grounding to fuselage |
In general I am opposed to running current thru the fuselage, but in the case of the white tail light, I am willing to make an exception. Is there any "approved" way of doing this so as to avoid causing corrosion due to the contact of dissimilar metals? Is a tin plated (it is tin isn't it?) ring terminal against bare aluminum going to cause a problem? Should it be covered/sprayed with something to protect it from moisture? Or is this just a bad idea under any circumstances?
Tom Sargent, RV-6A final assembly.
Posted: Tue Jun 02, 2009 7:31 am Post subject: grounding to fuselage |
At 08:48 AM 6/2/2009, you wrote:
| Quote: | In general I am opposed to running current thru the fuselage, but in
| Quote: | Is a tin plated (it is tin isn't it?) ring terminal against bare
Local concerns for the attachment of wires to
the airframe have been the topic of many pages
of "how to" and "how not" to do. In the
most hostile of environments, all the recommended
processes and materials add longevity to
the connection.
Our airplanes are seldom operated in conditions
that qualify as strenuous much less hostile.
Design goals for local grounding/bonding
speak to deleterious effects for failure to
faithfully observe recipes for success but they
seldom speak to the physics of the effects or
relative risks.
Keep in mind that for corrosion to occur, oxygen
laden moisture must be present in the joint.
Only then do the electrolytic effects of
dissimilar metals in ionized solutions
arise.
Yes, the tin plating of copper terminals #1
task is an electrolytic "buffer" between copper
and aluminum . . . but if you damage the tin
layer in any way during assembly or maintenance
of the joint, that barrier is breached and
the original copper-aluminum couple is exposed.
For all the fuss and froth about materials
control, the very best prophylactic against
corrosion call for making joints up with sufficient
pressure to produce "gas-tightness" enhanced
with a means by which future moisture ingress
is retarded assuages 99.99% of your concerns.
Join clean metals with robust, locking fasteners.
Coat the metals with silicon grease before joining.
And the joint will be fine for more than the
lifetime of airplane. You can "drink from the
fire hose" off grounding/bonding processes
in section 15 of AC43-13 offers a rigorous study.
There's nothing inherently evil about using the
airframe to carry power system currents. Modern
production aircraft made of aluminum have
countless airframe grounds crafted with due
diligence to the principals of gas-tightness
and choice of materials. These function as
desired for the lifetime of the airplane.
( -Thomas Paine 1776- )
rv-9a-online(at)telus.net Guest
Posted: Tue Jun 02, 2009 7:52 am Post subject: grounding to fuselage |
AC43.13-1B has an extensive discussion of aircraft bonding (grounding), including the proper procedure for connecting to the airframe and protection against corrosion.
This document is available in .pdf format if you don't have a hardcopy. It's a bit large to email, so if you can find it online for download, that's good.
If not, please let me know and I'll make other arrangements.
Vern Little
www.vx-aviation.com
Posted: Tue Jun 02, 2009 8:01 am Post subject: grounding to fuselage |
At 10:50 AM 6/2/2009, you wrote:
| Quote: | AC43.13-1B has an extensive discussion of aircraft bonding (grounding), including the proper procedure for connecting to the airframe and protection against corrosion.
If not, please let me know and I'll make other arrangements. |
AC43-13 is available for download at:
http://www.aeroelectric.com/Reference_Docs/FAA/
----------------------------------------- [quote][b]
Eric M. Jones
Posted: Wed Jun 03, 2009 4:54 am Post subject: Re: grounding to fuselage |
I suppose you could "get away with it" to use the airframe for grounding. But remember that the "ground" connection does EXACTLY the same thing as the positive conductor but backwards.
Wiring a tail light might be fine, but wiring the ground on a MAC/RAC trim box will almost certainly cause a noisy bar graph indicator, and the desire to keep down the loop resistance can be frustrated, and change with age. If you just can't stop yourself, then at least don't use the airframe or tubes as a high current ground for engine starting.
A customer of mine has an automobile built of steel. It has a battery in the trunk and requires an additional ground conductor--or the engine won't start. Hmmmm.......
"When facing a decision, ask yourself: what would I do if I wasn't afraid?"
—Russ Reeves
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Wed Jun 03, 2009 5:33 am Post subject: grounding to fuselage |
At 07:54 AM 6/3/2009, you wrote:
All of which goes to the system integration task
of deducing which devices are potential antagonists
(can be grounded about anywhere) and potential victims
(demand attention to wiring to avoid ground loop injection
of noise).
It's not a matter of "getting away with it". This
phraseology suggests an air of uncertainty or risk
for using the airframe as a ground. When accomplished
with a bit of study and understanding, then there is no
uncertainty, no risk and no wishful thinking for
"getting away with" anything.
| Quote: | "When facing a decision, ask yourself: what would I do if I wasn't afraid?"
Perhaps the better question is: "What do I need to understand to
mitigate my unfounded fear?"
mikef(at)apexconsultingse Guest
Posted: Wed Jun 03, 2009 6:14 am Post subject: grounding to fuselage |
Maybe it should be "ungrounded fear".....
On Wed, Jun 3, 2009 at 7:30 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
of noise).
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Mike
Mike Fontenot
Apex Consulting & Services LLC
Lakewood, Colorado
303 / 731-6645
mikef AT apexconsultingservices DOT com
