Step bushings
rnewman(at)tcwtech.com
PostPosted: Sun May 31, 2009 5:20 am    Post subject: Step bushings Reply with quote
I've added an additional note to the step bushing installion sheet regarding what to do when the hole in the step tube is not centered in the tube. Here's a copy of the revised install sheet for those that already have the step bushings. It's also now on our web site.
One other note, the idea behind the step bushings was not only to help resolve wiggly steps caused by the tube hole getting a little too big during the drilling process, but also to help over the long haul by providing a structure for the step bolt to actually provide a clamping force against, thereby allowing the step tube to be tightly secured to the step weld-mount.
Bob Newman
40176
www.tcwtech.com
step_bushing_install_info.pdf
 Filename:  step_bushing_install_info.pdf
 Filesize:  25.47 KB
 Downloaded:  264 Time(s)
indigoonlatigo(at)msn.com
PostPosted: Sun May 31, 2009 7:11 am    Post subject: Step bushings Reply with quote
Bob C
Can I please C please please C pretty please..live in your shop!!!!!
Subject: Step bushings
Date: Sun C 31 May 2009 09:13:53 -0400
One other note C  the idea behind the step bushings was not only to help resolve wiggly steps caused by the tube hole getting a little too big during the drilling process C but also to help over the long haul by providing a structure for the step bolt to actually provide a clamping force against C thereby allowing the step tube to be tightly secured to the step weld-mount.
Bob Newman
40176
www.tcwtech.com
PostPosted: Sun May 31, 2009 7:42 am    Post subject: Step bushings Reply with quote
RV builders are welcome at my shop anytime, stay as long as you like..... be warned, my friends call it Newman's work camp for a reason. Smile
Seriously, fellow builders are truly welcome to visit anytime,
-Bob Newman
