Posted: Thu May 28, 2009 9:40 am Post subject: Grey code output to multiple devices |
Folks,
I have a Narco AR 850 grey code altitude reporter. I would like to connect it to two devices (GPS and transponder) instead of just the transponder. The serial port on the GPS is being used for something else and it has grey code lines also.
Both the GPS and transponder have diode suppression in the grey code lines in order to prevent an off unit from dropping the signal to low.
What say ye.....can I do this - or will smoke escape....?
Ralph Capen
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
galsys(at)bezeqint.net Guest
Posted: Thu May 28, 2009 9:48 am Post subject: Grey code output to multiple devices |
forget it!
makes no sense
douglist(at)macnauchtan.c Guest
Posted: Thu May 28, 2009 2:38 pm Post subject: Grey code output to multiple devices |
At 20:48 +0300 5/28/09, Gaby Levin wrote:
forget it!
makes no sense
gi(at)av8r.de Guest
Posted: Thu May 28, 2009 10:50 pm Post subject: Grey code output to multiple devices |
I have the following installation:
KLN-94 GPS and a KT-76A Transponder. They both get the grey-code from
my ACK encoder. They're simply wired in parallel. It works fine.
regards
George
Am 29.05.2009 um 00:32 schrieb Doug McNutt:
<galsys(at)bezeqint.net>
forget it!
makes no sense
