Windsheild Installation ?
jeffrey-j-paris(at)excite
PostPosted: Fri May 29, 2009 8:53 am    Post subject: Windsheild Installation ? Reply with quote
Hello Europaphiles,
Quick question-Did I overlook something in the manual but I can't seem to find the instructions for the the windshield installation? Any ideas or suggestions would be greatly appreciated.
Cheers,
Jeff Paris Kit# A012 Monowheel Classic
Health Insurance You could save hundreds on health insurance. Click to get a quote now. Click Here For More Information [quote][b]
rlborger(at)mac.com
PostPosted: Fri May 29, 2009 9:23 am    Post subject: Windsheild Installation ? Reply with quote
Jeff,
Builder's Manual, Chapter 35 - Fitting Doors, page 429, Step 9.
Good luck,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On May 29, 2009, at 11:51, Jeffrey J Paris wrote:
Hello Europaphiles,
Cheers,
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
DuaneFamly(at)aol.com
PostPosted: Fri May 29, 2009 11:05 am    Post subject: Windsheild Installation ? Reply with quote
Jeff,
I just did my install, so here are a few things that I did..........First dry fit your windshield because you will probably have to trim it to fit. This will also give you an idea as to where you will need clamps or weights to keep the edge in contact while the epoxy cures.
I used a black marker to trace the trim line all around the perimeter. I called LP Aero, the windshield suppliers, and they suggested a cutoff wheel on a Dremel tool was OK for cuts bigger then 3/8". Further trimming should be done with 80 grit paper in a belt sander. They frowned on orbital sanders because of the sideways stress induced. You will need about a 2 mm space between all around for windshield expansion. Once it fits well, finish it with 150 grit paper on a wooden block to remove the 80 grit marks. This will prevent stress cracks later. Also round over all the edges, top and bottom, for the same reason.
When ready to install, I used the blue painters tape around the outside edge of the windshield and the fuselage for clean edges. I also remarked the inside area and used the blue tape along those marks for a clean edge.
I then first alcohol cleaned the epoxy edges of the windshield and fuselage followed by 80 grit paper to roughen the inside of the windshield where the epoxy needs to adhere and the contact portion of the fuselage. Vacuum, alcohol clean again.
You will need an assistant to simply get the windshield in place so do a dry run with the assistant using gloves. When you feel good about the procedure, you can mix the 420 epoxy. You don't need much. Once mixed and before adding the flox, I used a small brush to paint some epoxy onto the edges of the windshield and the fuselage. I then mixed in the flox until it did not run, put it into a disposable cake frosting bag and ran a bead all around the fuselage edge. With my assistant, we placed the windshield in place, centered it, and applied clamps and weight to insure full contact.
When I was sure all was well, I used my gloved finger to smooth the bead inside and out. I then carefully removed the tape and was able to inspect for any air bubbles under the windshield. If you find any, just press then out and add a weight until set. I always covered my weight bags in clear plastic kitchen wrap to prevent any epoxy from sticking to them.
Good luck....mine went easier than I expected and came out nice.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
Discover the variety of1871x1201491818/aol?redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B215225813%3B37274670%3Be%3Fhttp:%2F%2Frecipes.bisquick.bettycrocker.com%3FESRC%3D971>Get Recipes & Savings Now.
gholland(at)content-strea
PostPosted: Fri May 29, 2009 12:13 pm    Post subject: Windsheild Installation ? Reply with quote
Hi
2 things. A 1"+ Surform, a woodworking tool can be used to shave down to appropriate shape as well as other suggestions. It works well and doesn't create heat. Don't slip!
Secondly I used small self tappers pre drilled through Perspex to hold and tension screens into place after gluing by screwing them into upper fuselage. Several of us gotten this advice from a local Aircraft Company that service many Gliders in the area including lots of canopy replacement work. The holes left after glue sets and screws removed can be filled carefully and are hidden by paint line.
Gerry
Visit - www.EuropaOwners.org
