longg(at)pjm.com Guest
Posted: Thu May 28, 2009 6:26 am Post subject: Reading Potentiometer Values |
I have a handful of potentiometers at home and I want to verify the ohms
rating of each. What is the best/easiest or cheapest way to determine
their rating? The only real equipment I have is a simple DC tester with
ohms values. I will be using one to control the audio volume between my
D180 & GMA340.
Glenn
bob(at)bob-white.com Guest
Posted: Thu May 28, 2009 8:13 am Post subject: Reading Potentiometer Values |
Hi Glenn,
It sounds like you have what you need. Measure the resistance (ohms)
between the two outside pins. That will tell you what the resistance
of the pot is. There is another consideration when selecting a pot.
There linear and "audio" taper pots. A linear pot will change
resistance linearly with pot rotation. Turn it half way between CCW
and CW will give a reading of 1/2 the total resistance. An audio taper
will change exponentially. Rotating half way between CCW and CW will
result in a lower resistance between the center pin and the CCW pin and
a higher resistance between the center pin and the CW pin. The audio
taper is probably the best choice for your application.
Also, there should be some markings on the pot that will tell you what
value the pot is. Picking up a couple of random pots from by work
bench, one is marked "200 (ohm) LIN" which is pretty straightforward to
decode. the other is marked "A100K" which clearly indicates it is a
100 kohm pot, and I would guess the "A" means audio taper but I would
have to check.
(There are pots that aren't configured quite as described, but it
should work for most run of the mill pots.)
Bob W.
On Thu, 28 May 2009 10:23:23 -0400
<longg(at)pjm.com> wrote:
D180 & GMA340.
Glenn
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/
Posted: Thu May 28, 2009 9:40 am Post subject: Reading Potentiometer Values |
Excellent,
Thanks Bob.
Posted: Thu May 28, 2009 12:12 pm Post subject: Reading Potentiometer Values |
At 09:23 AM 5/28/2009, you wrote:
D180 & GMA340.
For simple volume control duties, simply
knowing the resistance value is sufficient.
Further, it's unlikely that the exact value
is critical. Potentiometers with values
ranging from 500 to perhaps as high as
10000 ohms would work for you. It's an
easy experiment and zero risk to the rest
of your system.
Digital multi-meters are inexpensive. Harbor
Freight has one that seems to be perpetually
on sale for under $5.
( -Thomas Paine 1776- )
