In flight adjustable props
malpass
PostPosted: Thu May 28, 2009 6:10 am    Post subject: In flight adjustable props Reply with quote
One thing to be cautious of installing the adjustable props, is that you will take a way the "light sport" qualifications of your aircraft, if that is important to you.
Bill Malpass
Kitfox model III 582 grey
Ivo 3 blade ground adjustable prop
kitfox III w/ 582 greyhead
clint_bazzill(at)hotmail.
PostPosted: Thu May 28, 2009 8:57 am    Post subject: In flight adjustable props Reply with quote
Only if the control for pitch is in the cockpit.  If you already have your airplane certified no problem C when using with light sport C put the switch in the engine area C it becomes a ground adjustable electric prop.
Clint with IVO UL in 912ULS
Subject: In flight adjustable props
Date: Thu C 28 May 2009 10:02:29 -0400
One thing to be cautious of installing the adjustable props C is that you will take a way the "light sport" qualifications of your aircraft C    if that is important to you.
Bill Malpass
ronics.com
ww.matronics.com/contribution
