glastar(at)gmx.net Guest
Posted: Thu May 28, 2009 2:08 am Post subject: How do you change the VFR code on the Garmin GTX 330 |
Hi Michael,
as my plane is currently in the driveway I just checked, I have SW
Version 4.01 my manual also refers to this.
I've just tested it as following and it works:
FUNC ON (I'm in Diagnostic mode)
12x FUNC (I'm on Operation config page with VS rate / Format / VRF ID
/ALT Alert Dev)
3x CRSR (the VFR ID Field is highlighted)
7 0 0 0 (Field has changed to 7000 Cursor is on 1st digit of ALT Alert Dev)
OFF (switching it off and saving)
Stein, any idea what Version 6 of the SW has different then 4.x (that is
two major releases) and how to get an update?
br
Werner
Michael Wellenzohn wrote:
Thank you for all your input. I tried it out and it still didn't work. All other fields work and stay after the power cycle. I have software version 6.0 installed. Is there probably a setting that always resets the VFR id to factory default that needs to be disabled?
Michael
RV-10 builder (avionics, wiring)
#511
http://forums.matronics.com/viewtopic.php?p 45625#245625
