Grumman 2 place
dlm46007(at)cox.net
PostPosted: Wed May 27, 2009 1:12 pm    Post subject: Grumman 2 place Reply with quote
I talked with the Grumman guru and found the following. The worst of the lot was an AA-1 with an O235 engine. The wing was very fast and stalled about 60kts; not the characteristics desired in a trainer. Grumman modified the wing airfoil and came with the AA-1A, AA-1B, and AA-1C. the later models had the modified wing that reduced the stall and many of those have now been STCed to a O320 150 HP engine. Grumman made an four place AA-5 airframe, if it has the 150 HP engine it is really a two place aircraft ( Traveler) and pretty anemic. If it has the O360 180HP engine it has respectable performance and is called the Tiger.
cloudvalley(at)comcast.ne
PostPosted: Wed May 27, 2009 5:34 pm    Post subject: Grumman 2 place Reply with quote
Hi!
We own a low-time 79 Tiger and love it!
Brian and Ruth Preston
 Filesize:  102.44 KB
 Viewed:  1252 Time(s)
james.k.hovis(at)gmail.co
PostPosted: Fri May 29, 2009 12:14 pm    Post subject: Grumman 2 place Reply with quote
I miss my AA-1A with the 160hp engine!
On Wed, May 27, 2009 at 4:10 PM, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] I talked with the Grumman guru and found the following. The worst of the lot was an AA-1 with an O235 engine. The wing was very fast and stalled about 60kts; not the characteristics desired in a trainer. Grumman modified the wing airfoil and came with the AA-1A, AA-1B, and AA-1C. the later models had the modified wing that reduced the stall and many of those have now been STCed to a O320 150 HP engine.  Grumman made an four place AA-5 airframe, if it has the 150 HP engine it is really a two place aircraft ( Traveler) and pretty anemic. If it has the O360 180HP engine it has respectable performance and is called the Tiger.
get="_blank">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com
