Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27955 Location: Toledo Washington (KTDO) USA
Posted: Wed May 27, 2009 11:52 am Post subject: Packing The Wheel Bearings... |
Dear Listers,
I'm just about to put the wheels on the axles. The manual indicates what kind of grease to use, but doesn't really indicate whether you're suppose to use *more* than is already gooped in the bearing when you open the Cleveland box. There seems to be a fair amount of grease already there. What's the common notion on this?
Thanks!
RV-8 #82880 N998RV
Gear Mounted (whew), Adding Wheels & Brakes...
104.49 KB |
1774 Time(s) |
_________________ Matt Dralle
estone(at)mchsi.com Guest
Posted: Wed May 27, 2009 12:21 pm Post subject: Packing The Wheel Bearings... |
Tim Olson
Posted: Wed May 27, 2009 12:40 pm Post subject: Packing The Wheel Bearings... |
If they've sufficiently lubed between the rollers to pack it all in, and
there is enough grease next to the seal and around it, you should be
good to go. The thing you don't want to forget to do though is to
oil the felt seals if you have felt seals. Definitely do that.
Tim Olson - RV-10 N104CD
Matt Dralle wrote:
| Quote: | Dear Listers,
Thanks!
Matt Dralle RV-8 #82880 N998RV Gear Mounted (whew), Adding Wheels &
Brakes...
