Bolt torque
mlord001(at)new.rr.com
PostPosted: Wed May 27, 2009 4:41 am    Post subject: Bolt torque Reply with quote
Thanks Guys for the heads up on the AN bolt torque.
I will pull all of my wing bolts and replace them with new.
To explain where I got the bogus information. I googled
AN Bolt torque and a ultralightflyers.org/documents came up
I clicked on it and AN Bolt torque spec.xls document came up
with the faulty information.
Mike Lord
purplemoon99(at)bellsouth
PostPosted: Wed May 27, 2009 1:43 pm    Post subject: Bolt torque Reply with quote
Juan Vega Jr
PostPosted: Fri May 29, 2009 5:22 am    Post subject: Bolt torque Reply with quote
I just checked it out. Its a good table to use. the info is correct, you just need to read the top of the column where it says foot lbs or inch lbs. I am saving it to use later. it is attached below for all.
Juan
an_torque_specs.pdf
 Filename:  an_torque_specs.pdf
 Filesize:  9.62 KB
 Downloaded:  10364 Time(s)
Juan Vega Jr
Michael,
now I see, i think the numbers have an extra zero. trash that file!
JUan
JohnDRead(at)aol.com
PostPosted: Fri May 29, 2009 5:38 am    Post subject: Bolt torque Reply with quote
Juan;
Your numbers are off the wall wrong! Please look in the Zenith Construction Standards for the correct numbers.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Discover the vari1222831871x1201491818/aol?redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B215225813%3B37274670%3Be%3Fhttp:%2F%2Frecipes.bisquick.bettycrocker.com%3FESRC%3D971>Get Recipes & Savings Now.
pdn8r(at)yahoo.com
PostPosted: Fri May 29, 2009 5:50 am    Post subject: Bolt torque Reply with quote
Torgue values from 43.13 attached.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Fri, 5/29/09, Juan Vega <amyvega2005(at)earthlink.net> wrote:
Subject: Re: Bolt torque
To: zenith-list(at)matronics.com, zenith-list(at)matronics.com
Date: Friday, May 29, 2009, 9:22 AM
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net)>
Michael,
JUan
Torque_Values.pdf
 Filename:  Torque_Values.pdf
 Filesize:  1.04 MB
 Downloaded:  344 Time(s)
pete(at)usjabiru.com
PostPosted: Fri May 29, 2009 6:10 am    Post subject: Bolt torque Reply with quote
That chart is not correct. Please look at the torque values in FAA Advisory Circular 43-13 - chapter 7 paragraph 7-40 and the table following. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2007.pdf
You will see that limit torque for AN3 is 40 inch lbs.
Most aircraft designers will specify torque in accordance with this AC.
Pete
PostPosted: Fri May 29, 2009 6:14 am    Post subject: Bolt torque Reply with quote
Here is the FAA torque chart from AC43-13. Note that values are in inch lbs
Pete
Torque_Chart_AC43-13.pdf
 Filename:  Torque_Chart_AC43-13.pdf
 Filesize:  36.23 KB
 Downloaded:  331 Time(s)
PostPosted: Fri May 29, 2009 6:25 am    Post subject: Bolt torque Reply with quote
Here's a question for all. Is this lack of understanding of torque values behind the alleged wing failure problems?
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 5/29/2009 8:15:30 A.M. Mountain Daylight Time, pete(at)usjabiru.com writes:
[quote]Here is the FAA torque chart from AC43-13. Note that values are in inch lbs
Pete
bryanmmartin
PostPosted: Fri May 29, 2009 6:56 am    Post subject: Bolt torque Reply with quote
I don't recall seeing bolt failure mentioned in any of the accident
reports.
John Read
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
