Overhauling Mono swing arm dampers
paul.the.aviator(at)gmail
PostPosted: Tue May 26, 2009 2:17 pm    Post subject: Overhauling Mono swing arm dampers Reply with quote
Hi all,
I recently replaced the swing arm dampers on my monowheel.  The aircraft has accumulated about 800 hours over 4.5 hours and although they didn't seem to need replacing, it just seemed like it was easier to do this while the engine was off and the aircraft was a part.
I was wondering if anyone has looked into sending these back to Hagon for re valving, or is this impractical / uneconomical ?
Regards,  Paul
kjburns(at)btinternet.com
PostPosted: Tue May 26, 2009 3:07 pm    Post subject: Overhauling Mono swing arm dampers Reply with quote
http://www.falconshockabsorbers.co.uk/repair001.htm
Try these Paul
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Sent: Tuesday, 26 May, 2009 11:17:13 PM
Subject: Europa-List: Overhauling Mono swing arm dampers
Hi all,
Regards, Paul
[quote]http://www.matronics.com/Navigator?Europa-p://www.matronics.com/contribution" target=_blank rel=nofollow>http://w=======================
