Thruster87
Posted: Sun May 31, 2009 8:47 pm Post subject: Bendix 10-357210-1 Ignition switch |
Bought a rotary ignition switch and would like to know which terminal goes to what on a Jabiru 3300 engine.Terminals marked R,L LR,BO,Batt ,S and G. L= left mag,R= right mag G= ground.Don't know where to connect the rest [Bendix 10-357210-1 Ignition switch key OFF,L,R,Both and twist to start] Any help would be appreciated. Cheers T87
bakerocb
Posted: Mon Jun 01, 2009 3:51 am Post subject: Bendix 10-357210-1 Ignition switch |
6/1/2009
Hello Thruster87, You wrote: "Bought a rotary ignition switch and would like
to know ......"
Another one of the advantages of using two toggle switches for this purpose
instead of the unreliable rotary switch is to avoid fumbling around with the
confusing wiring required.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 09:50:01 PM PST US
Subject: Bendix 10-357210-1 Ignition switch
to what
10-357210-1
Posted: Mon Jun 01, 2009 6:24 pm Post subject: Bendix 10-357210-1 Ignition switch |
Unless you have a shower-of-sparks ignition system,
you don't need BO. If the engine doesn't require
starting on one ignition only, you don't use the LR
terminal either.
See Figure Z-26 at:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z26K_27K.pdf
( -Thomas Paine 1776- )
Thruster87
Posted: Mon Jun 01, 2009 6:50 pm Post subject: Re: Bendix 10-357210-1 Ignition switch |
terminal either.
See Figure Z-26 at:
---------------------------------------- | Much appreciated Cheers T87
