hotwheels
Posted: Tue May 26, 2009 11:36 am Post subject: Fuel System Section FF4-3 ... Crating Strap Hanger |
The Fuel System section FF4-3 calls out fabrication of a hanger using a "crating strap". My crates are long gone and I'm assuming that a piece of strap isn't included in the kit...
Anyone have ideas about what could be used instead? I have a pretty good collection of odds and ends in my homer bucket that might provide possible candidates. If all else fails, Home Depot is just down the road.
Jay
pascal(at)rv10builder.net Guest
Posted: Tue May 26, 2009 12:25 pm Post subject: Fuel System Section FF4-3 ... Crating Strap Hanger |
not seeing the step you're asking about. I have Tim's 12/08/06 version and
there is no reference to a crating strap on page FF4-3
Sent: Tuesday, May 26, 2009 12:36 PM
Subject: Fuel System Section FF4-3 ... Crating Strap Hanger
Jay
http://forums.matronics.com/viewtopic.php?p 45431#245431
hotwheels
Posted: Tue May 26, 2009 12:37 pm Post subject: Re: Fuel System Section FF4-3 ... Crating Strap Hanger |
FF4-3 Rev 0 is attached...
Jay
| pascal(at)rv10builder.net wrote: | not seeing the step you're asking about. I have Tim's 12/08/06 version and
To: <rv10>
Jay
FF4-3.pdf |
68.21 KB |
543 Time(s) |
bcondrey
Posted: Tue May 26, 2009 12:44 pm Post subject: Fuel System Section FF4-3 ... Crating Strap Hanger |
Maybe call John A. - he just got his RV-9 wing kit!
Bob
drfred(at)suddenlinkmail. Guest
Posted: Tue May 26, 2009 1:30 pm Post subject: Fuel System Section FF4-3 ... Crating Strap Hanger |
Jay;
Looks like all they are trying to do is make an inexpensive bracket to
keep the two hoses from chafing. You could use some aluminum angle and
put two pieces back to back and make the same bracket. Clearance hole
for the bolt in one angle and longer rivets to hold the hole thing
together.
Dr Fred.
hotwheels
Posted: Tue May 26, 2009 1:54 pm Post subject: Re: Fuel System Section FF4-3 ... Crating Strap Hanger |
Someone pointed out to me that there's a newer FF4 revision. It doesn't mention the goofy bracket. Thanks!
Jay
