Prop Locks on 690 Commander
nick(at)container.com
PostPosted: Tue May 26, 2009 9:01 am    Post subject: Prop Locks on 690 Commander Reply with quote
Has anyone out there had a prop lock string retainer come off with engine running ? This happened to my TPE 331 -10 . It appears that the spring pressure and centrifugal force of the retainer was all pressing against the cotter pin .The pin sheared off and the spring and retain fell out of my spinner as the engine ran down ….cotter pin was cad plated ,should it be stainless??? N674NM
Nicolas E. Martin
Martin Container, Inc.
1402 E. Lomita Blvd.
Wilmington, Ca 90748
Tel: 310-830-5000, Fax : 310-830-2562
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Randy Dettmer, AIA
Sent: Sunday, May 24, 2009 9:06 AM
Subject: RE: Sump Drain valve for 680F
Thanks guys. Good reason to go for a flight to burn up most of the fuel from the center tank before draining in to jugs. Randy.
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher
Sent: Sunday, May 24, 2009 8:28 AM
Subject: Re: Sump Drain valve for 680F
Drain the tank, you don't want to fool around with combustibles under your loved possession.
Tom
C-GISS
 Filesize:  2.9 KB
 Viewed:  1433 Time(s)
yourtcfg(at)aol.com
PostPosted: Tue May 26, 2009 5:48 pm    Post subject: Prop Locks on 690 Commander Reply with quote
Nope, I have however had the springs beak and the pins stick. In ether case the propeller will feather. jb
 Filesize:  2.9 KB
 Filesize:  2.9 KB
 Filesize:  2.9 KB
