Transponder adjustment
gavanne(at)iconz.co.nz
PostPosted: Sun May 24, 2009 2:47 pm    Post subject: Transponder adjustment Reply with quote
Hi all…
Has anyone had any experience of adjusting the received output from the transponder?
I’m running a Garmin 320A transponder through an Ameri-King 350 encoder. It works fine except that the receiving station is getting a readout 300 ft low. (eg when I am at 5500ft, radar says I am at 5200ft)
There are a couple of adjustment screws on the encoder + & - . Has anybody adjusted these and how sensitive are they?
Thanks, Gavin Lee ZK-EPA…….55 hours and counting
bill.sue(at)orcon.net.nz
PostPosted: Mon May 25, 2009 1:38 am    Post subject: Transponder adjustment Reply with quote
Hi Gavin, I am is South Africa at present. The avionics guys at Hamilton
Aero Avionics did mine for me, only took him a few minutes.
Look after NZ while I am away.
Cheers
Bill Sisley
Hi all.
transponder?
I'm running a Garmin 320A transponder through an Ameri-King 350 encoder.
It
anybody
Thanks, Gavin Lee ZK-EPA...55 hours and counting
raimo.toivio(at)rwm.fi
PostPosted: Mon May 25, 2009 2:43 am    Post subject: Transponder adjustment Reply with quote
Hi Gavin and all
I have a combination Ameri-King 350 encoder and Bendix-King KT76A/78A transponder and have same sympthom as you eg a readout 200-300 feet too low.
Also - like Bob - I hear a low blimb or so through my headset when in C-mode and it is sending eg about once every two or three seconds.
What to do?
Cheers, Raimo
OH-XRT 103 hrs and testing Airmaster & Trio
