Sump Drain valve for 680F
rcdettmer(at)charter.net
PostPosted: Sat May 23, 2009 1:06 pm    Post subject: Sump Drain valve for 680F Reply with quote
The last time I drained fuel from the center tank sump, the valve did not close completely and fuel continued to drip overboard. After opening and closing several times, the dripping stopped. I have not opened the valve since, for fear of it sticking open again. Has anybody experienced this situation..?? I was unable to identify the valve in my parts manual. Is it the same in all Commanders..?? I may need a replacement valve. Anyone have one..?? Thanks.
Randy Dettmer, AIA
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
 Filesize:  2.9 KB
 Viewed:  9326 Time(s)
moe-rosspistons(at)hotmai
PostPosted: Sat May 23, 2009 2:20 pm    Post subject: Sump Drain valve for 680F Reply with quote
Randy,
This valve (the twist valve that you access through the small door under the wing) looks suspiciously like the Eelco valve that I used to shut off the fuel in my D Altered 57 Chevy. Drag Car equipped with early Hilborn Injectors in about 1972. Meaning that it was military surplus. Most likely the valve needs to be removed and new "o" rings installed.
You are correct that the valve is not listed in the Commander parts book, which is a very good thing..........................
Regards.
Moe
N680RR
Proud Holder of The Golden Pedal Award
From: Randy Dettmer, AIA (rcdettmer(at)charter.net)
Sent: Saturday, May 23, 2009 1:57 PM
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Subject: Sump Drain valve for 680F
Randy Dettmer, AIA
680F / N6253X
[img]cid:A2013AAB5C0C4AB6B7350C9AE7B6E8A8(at)moemills1[/img]
663 Hill Street
 Filesize:  2.9 KB
PostPosted: Sun May 24, 2009 6:38 am    Post subject: Sump Drain valve for 680F Reply with quote
Hi Moe,
Thanks for the response. I think the challenge will be to get the valve removed and the fuel line capped without spraying gas all over the place. And then re-installing it. Any suggestions, short of de-fueling the tank..??
Randy
663 Hill Street
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe-rosspistons
Sent: Saturday, May 23, 2009 3:15 PM
Subject: Re: Sump Drain valve for 680F
[b]Randy,[/b]
[b]This valve (the twist valve that you access through the small door under the wing) looks suspiciously like the Eelco valve that I used to shut off the fuel in my D Altered 57 Chevy. Drag Car equipped with early Hilborn Injectors in about 1972. Meaning that it was military surplus. Most likely the valve needs to be removed and new "o" rings installed.[/b]
[b]You are correct that the valve is not listed in the Commander parts book, which is a very good thing..........................[/b]
[b]Regards.[/b]
[b]Moe[/b]
[b]N680RR[/b]
[b]Proud Holder of The Golden Pedal Award[/b]
Randy Dettmer, AIA
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  9324 Time(s)
scottmain
PostPosted: Sun May 24, 2009 6:43 am    Post subject: Sump Drain valve for 680F Reply with quote
That sump is the low spot in the system. get a bunch of gerry cans and drain it dry. I know........someone stole all my gas one night. wasn't a drop left.
In a message dated 5/24/2009 10:39:30 A.M. Eastern Daylight Time, rcdettmer(at)charter.net writes:
Hi Moe,
Randy
663 Hill Street
[b]Randy,[/b]
[b]Regards.[/b]
[b]Moe[/b]
[b]N680RR[/b]
Randy Dettmer, AIA
680F / N6253X
663 Hill Street
Recession-proof vacation ideas. 2">
 Filesize:  2.9 KB
 Filesize:  2.9 KB
tfisher(at)commandergroup
PostPosted: Sun May 24, 2009 7:28 am    Post subject: Sump Drain valve for 680F Reply with quote
Drain the tank, you don't want to fool around with combustibles under your loved possession.
Tom
C-GISS
 Filesize:  2.9 KB
PostPosted: Sun May 24, 2009 8:06 am    Post subject: Sump Drain valve for 680F Reply with quote
Thanks guys. Good reason to go for a flight to burn up most of the fuel from the center tank before draining in to jugs. Randy.
663 Hill Street
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher
Sent: Sunday, May 24, 2009 8:28 AM
Tom
C-GISS
 Filesize:  2.9 KB
yourtcfg(at)aol.com
PostPosted: Mon May 25, 2009 8:45 pm    Post subject: Sump Drain valve for 680F Reply with quote
I have removed several with the airplane fueled, you need to be careful, well organized and fast!! jb
 Filesize:  2.9 KB
 Viewed:  9321 Time(s)
 Filesize:  2.9 KB
kamala(at)MSN.COM
PostPosted: Tue May 26, 2009 6:30 am    Post subject: Sump Drain valve for 680F Reply with quote
I have replaced the drain valves in 70QT w/ the easy and rebuildable cessna drains.  they work very well.  Ck w/ gary Kromer at commander aero for parts and paper work. gmc
Date: Tue C 26 May 2009 00:42:17 -0400
I have removed several with the airplane fueled C you need to be careful C well organized and fast!!  jb
 Filesize:  2.9 KB
 Viewed:  9319 Time(s)
 Filesize:  2.9 KB
BobsV35B(at)aol.com
PostPosted: Sat May 30, 2009 6:38 pm    Post subject: Sump Drain valve for 680F Reply with quote
Good Evening Randy,
Just be sure to properly ground the fuel tank to the receptacle into which the fuel is being drained. There have been many airplanes and aircraft repair stations burned to the ground during defueling operations. If you use plastic containers, be extra careful and run a bare copper wire from inside the fuel tank on down into the fuel in the accepting container. Ya can't be too careful!
Happy Skies,
Old Bob
Piper PA-20
Downers Grove, Illinois
In a message dated 5/24/2009 11:07:29 A.M. Central Daylight Time, rcdettmer(at)charter.net writes:
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
yourtcfg(at)aol.com
PostPosted: Sun May 31, 2009 8:17 am    Post subject: Sump Drain valve for 680F Reply with quote
DE-FUEL ONLY OUTSIDE THE HANGAR, NEVER, NEVER INSIDE!!!! jb
rsrandazzo(at)precisionma
PostPosted: Sun May 31, 2009 9:09 am    Post subject: Sump Drain valve for 680F Reply with quote
Depends on the goal, I suppose. J
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com
Sent: Sunday, May 31, 2009 9:17 AM
nico(at)cybersuperstore.c
PostPosted: Sun May 31, 2009 2:58 pm    Post subject: Sump Drain valve for 680F Reply with quote
You mean like instantly selling the hangar and plane to the insurance company?
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Robert S. Randazzo
Sent: Sunday, May 31, 2009 10:08 AM
Subject: RE: Sump Drain valve for 680F
-----Original Message-----
Sent: Sat, 30 May 2009 7:36 pm
Good Evening Randy,
Happy Skies,
Old Bob
Piper PA-20
In a message dated 5/24/2009 11:07:29 A.M. Central Daylight Time, rcdettmer(at)charter.net (rcdettmer(at)charter.net) writes:
Wanna slim down for summer? Go to America Takes it Off to learn how.
3 [quote][b]
steve2(at)sover.net
PostPosted: Mon Jun 01, 2009 11:59 am    Post subject: Sump Drain valve for 680F Reply with quote
Neat opportunity to see just how much fuel the ship might REALLY hold when you refill.
Our 500B took 150 gallons to fill a completely defueled 156 gallon system once, and 150 gallons another time parked in the opposite direction at the same pump.
Either we're getting chubby gallons, or maybe we don't really hold 156.
I guess some folks like the simplicity of all the tanks draining into one, but I sure sometimes miss having fuel squirreled away in other tanks on a long drive home.
Steve
PostPosted: Mon Jun 01, 2009 3:08 pm    Post subject: Sump Drain valve for 680F Reply with quote
I would take the opportunity of an empty fuel system to clamp a clear hose to the center tank drain, hook the other end of the hose to the side/top of the fuselage and add 10 US gallons at a time. At each 10 USG increment verify the indication on the fuel gauge as well as mark the clear hose.
Once all of the above is completed you have a calibrated fuel gauge as well as a calibration hose so when the fuel is down below dippable range on the wing you still can verify the exact quantity of fuel in the center tank using the hose, in a sense dipping the tank.
So if you are from the school that does not trust electrical fuel gauges then you can still measure (dip) the center tank.
Tom,
the swimmer.
