hlang(at)bluewin.ch Guest
Posted: Fri May 22, 2009 12:51 am Post subject: Kitfox - how high have you gone ?Kitfox - how high have you |
Hi Jan
That is the way to deal with such things. If you want to compare apples
with apples definitions are necessary.
With regard to the question about 4 stroke or 2 stroke engines (Rotax):
the difference lays in the carburettor, I think. The 4 stroke engines
use CV carburettors which compensate for the altitude, at least partly.
Heinz
