SV: Pitts-List Digest: 0 Msgs - 05/20/09
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pitts-List
havard(at)cloud-dancer.ne
PostPosted: Thu May 21, 2009 12:43 am    Post subject: SV: Pitts-List Digest: 0 Msgs - 05/20/09 Reply with quote
Hello out there!
I am quite alone here in Norway with a Pitts S2a. I have a question if any
one knows of corrosionproblems on the oil coolers. This plane has been
standing for 10 years before finally its flying again. Any comments if they
are safe to use further on or should they be changed with new once?
Håvard
-----Opprinnelig melding-----
Fra: owner-pitts-list-server(at)matronics.com
[mailto:owner-pitts-list-server(at)matronics.com] På vegne av Pitts-List Digest
Server
Sendt: 21. mai 2009 08:58
Til: Pitts-List Digest List
Emne: Pitts-List Digest: 0 Msgs - 05/20/09
Today's complete Pitts-List Digest can also be found in either of the
of the Pitts-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter
09-05-20&Archive=Pitts
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=
2009-05-20&Archive=Pitts
Pitts-List Digest Archive
Total Messages Posted Wed 05/20/09: 0
Today's Message Index:
Checked by AVG - www.avg.com
17:59:00
- The Matronics Pitts-List Email Forum -
http://www.matronics.com/Navigator?Pitts-List
pukndg(at)mindspring.com
PostPosted: Thu May 21, 2009 5:38 am    Post subject: SV: Pitts-List Digest: 0 Msgs - 05/20/09 Reply with quote
Hervard,
Try posting your question on the following forum: www.biplaneforum.com.
These guys seem to have all the answers.
Hank
[Original Message]
From: Håvard Nærø Iversen <havard(at)cloud-dancer.net>
To: <pitts-list(at)matronics.com>
Date: 5/21/2009 1:46:24 AM
Subject: SV: Pitts-List Digest: 0 Msgs - 05/20/09
=?iso-8859-1?Q?H=E5vard_N=E6r=F8_Iversen?= <havard(at)cloud-dancer.net>
Hello out there!
they
Håvard
Digest
Server
HTML Version:
Text Version:
17:59:00
pittsflyers1s(at)yahoo.co
PostPosted: Thu May 21, 2009 8:11 am    Post subject: SV: Pitts-List Digest: 0 Msgs - 05/20/09 Reply with quote
While I am not an A&P, if the exterior shows no damage or corrosion, you are pro bably OK. A good ground run and subsequent external inspection would show any leaks.
Alternatively, remove it and take it into a radiator shop and have them clean it for you, they may also be able to pressure test it.
Dave M
To: pitts-list(at)matronics.com
Sent: Thursday, May 21, 2009 1:41:04 AM
--> Pitts-List message posted by: =?iso-8859-1?Q?H=E5vard_N=E6r=F8_Iversen?= <havard(at)cloud-dancer.net (havard(at)cloud-dancer.net)>
Hello out there!
Håvard
Fra: owner-pitts-list-server(at)matronics.com (owner-pitts-list-server(at)matronics.com)
[mailto:owner-pitts-list-server(at)matronics.com (owner-pitts-list-server(at)matronics.com)] På vegne av Pitts-List Digest
Server
HTML Version:
=2009-05-20&Archive=Pitts
Text Version:
Checked by AVG -
gcostabile(at)embarqmail.
PostPosted: Sun May 24, 2009 7:35 am    Post subject: SV: Pitts-List Digest: 0 Msgs - 05/20/09 Reply with quote
Hvard,
Don’t know if you’ve made any progress, but you should be wary of any corrosion indications. Two A&P’s on our field changed out the engine in a Decathlon due to internal corrosion. They estimated it was within three flight hours of failing when they took it out of service. This particular airplane was located in a humid, salty environment (coastal town in Northwest Florida), and was only flown 10 hours in the last 18 months. Lack of use is a sure way to internally corrode an engine.
If your engine has an oil filter, cut it open, collect the filter element, place it in a plastic container, and then rinse it in a bath of 100LL. Use your fingers to extract as much “gunk” out of the element as possible. Carefully drain off the 100LL until there is remaining soot in the bottom of the container – kind of like panning for gold. >From there, place a magnet on the external part of the container and “pull” the soot up the side of the container. You should see very little metal on the inside of the container in response to the magnet. “Very little” is hard to quantify or visualize if you’ve never seen this before, and difficult to describe in words. Imagine a good “pinch” of pepper added to a recipe in cooking; if there’s a good “pinch” of metal in response to the magnet, be suspicious. If not, then follow Dave’s guidance and have the cooler inspected and cleaned by a radiator shop.
Best regards,
Gregg C
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pitts-List All times are GMT - 8 Hours
