paulmillner
Joined: 09 May 2007 Posts: 21 Location: Berkeley, California
Posted: Mon May 25, 2009 7:17 pm Post subject: Ground Power Receptacle - 3 pin |
>> I assume that the military and airlines use the pin for the same thing.
In the 70's, Cessna used that small third pin, hotted up by the external
power source, to both close the ground power contactor, connecting the
external power source to the bus, *and* to energize an avionics relay,
which disconnected the avionics bus from the main bus. The relay coil
was diode or'd with the starter contactor coil circuit... so turning the
key to start *also* disconnected the avionics bus.
Where it gets exciting is when the diode from the starter contactor
fails as a short.. then, connecting ground power causes the prop to
start spinning, Youza!
Paul
_________________ Paul Millner, Berkeley CA [OAK] |
Posted: Tue May 26, 2009 2:53 pm Post subject: Ground Power Receptacle - 3 pin |
At 10:13 PM 5/25/2009, you wrote:
<paulmillner(at)compuserve.com>
external power source, to both close the ground power contactor,
connecting the external power source to the bus, *and* to energize
an avionics relay, which disconnected the avionics bus from the main
bus. The relay coil was diode or'd with the starter contactor coil
circuit... so turning the key to start *also* disconnected the avionics bus.
Yeah . . . I remember that setup. We sure thought
it was a good idea . . . at the time . . .
( -Thomas Paine 1776- )
