europa(at)pstewart.f2s.co Guest
Posted: Mon May 18, 2009 12:54 pm Post subject: oil leak |
we have just run the engine up (914) for the third time. After about 5 min there
was oil dripping from the right hand airbox drain and the air filter is soaked
in oil. There is no apparent leak from anywhere else. The oil tank has never
been over filled. The engine does not appear to be burning oil. It appears that
it has been drawn up into the airbox from the turbo - but why the air filter
soaked in oil? The first couple of engine runs (couple of months ago) there was
no evidence of oil leaking anywhere. Any thoughts?
Paul
G-GIDY
acrojim7534(at)YAHOO.COM Guest
Posted: Mon May 18, 2009 1:41 pm Post subject: oil leak |
Paul
Usually when oil is in the airbox, the bearing-oil seal is bad on the intake side of the turbo
If the engine is burning white smoke look at the bearing on the exhaust side of the turbo.
Jim Brown
--- On Mon, 5/18/09, europa(at)pstewart.f2s.com <europa(at)pstewart.f2s.com> wrote:
Quote: |
From: europa(at)pstewart.f2s.com <europa(at)pstewart.f2s.com>
Subject: oil leak
Date: Monday, May 18, 2009, 8:42 PM
--> Europa-List message posted by: europa(at)pstewart.f2s.com (europa(at)pstewart.f2s.com)
no evidence of oil leaking ar?Europa-List" target=_blank>http://www.matronics.com/Navigator?Europa-Li --> http://www.matronics.c===================
frans(at)paardnatuurlijk. Guest
europa(at)pstewart.f2s.com wrote:
Quote: | we have just run the engine up (914) for the third time. After about 5 min there
Looks like a turbo problem. Oil leaking via the bearing into the inlet.
The air stream takes small oil bubbles up into the airbox, but the
majority of the oil will probably dribble into the air filter.
Could there be a problem with the turbo oil return line? Should go to
the auxiliary oilpump, and from there to the oil tank. If you disconnect
it at the oil tank and run the engine, oil should be dripping out of
this line. If no oil shows up, then you have found the problem.
Wait a minute! You ran the engine a couple of months ago for the last time?
Maybe the oil flowed back, and sucked some air in the turbo oil return
pump. Once there is air in this pump, it won't pump oil anymore, and the
oil will need to find another way out. Most likely than it will overflow
into the inlet air channel.
You can also have air in the oil system if you (or someone else) turned
the propeller the wrong way. Never tested it myself, but I've heard that
just a quarter of a turn in the wrong direction can allow air to get
into the oil system.
Do the test with the oil return line, and if it doesn't produce oil, you
will have to prime the oil system. This works great by pressurizing the
oil tank and turning the propeller by hand until oil comes out of the
oil return line.
Frans Veldman
erichdtrombley(at)juno.co Guest
Posted: Mon May 18, 2009 6:39 pm Post subject: oil leak |
Paul,
I had a similar experience when I first commissioned the engine. Sounds like the check valve on the turbo is/was stuck. The stuck check valve allows oil to fill up the turbo on both the intake and exhaust sides. Upon start up the oil on the intake side is blown into the air box where it then collects and drains as you have observed. While you can remove the check valve and clean it, more than likely it will re seat itself.
Good luck,
Erich Trombley
N28ET Classic Mono 914
Paul
____________________________________________________________
Fast Computer Training. Click here.
http://thirdpartyoffers.juno.com/TGL2131/fc/BLSrjnsC7v6Knu7eDjYzNVAlYb8GYEnlVsXxvffM7p2QMNEm4AXZJ1fJAFC/
Posted: Mon May 18, 2009 8:24 pm Post subject: oil leak |
Hi! Paul
Did you "burp" the oil tank by propping the engine prior to start up to
pull oil out of the sump?
Sounds like oil through the turbo seal which I understand is ceramic and
probably needs to get well up to temperature at least once to make it
good? However a leaking turbo seal could pass oil up to the airbox as
well as to the air filter.
The oil in the drain also sounds like some leak past a valve guide. I
just had that on start up after a long period standing.
I take it that the "Ps" and "Ts" were all good ?
Have you purged air locks from the oil system as per the Rotax
instructions?
Sounds like you need some qualified advice IMHO.
Bob Harrison G-PTAG
paul.the.aviator(at)gmail Guest
Posted: Tue May 19, 2009 1:52 am Post subject: oil leak |
Hi Paul,
I do recall that many years ago, John Hurst had a similar problem and he removed the check valve to inspect and clean it. Unfortunately when he re assembled everything he put the check valve in back to front and the turbo was instantly destroyed at engine start up.
I guess the moral of the story is that you need to be careful when playing around with this area.
Cheers, Paul
kevann(at)gotsky.com Guest
Posted: Tue May 19, 2009 7:12 am Post subject: oil leak |
I, too, had a similar experience and asked about it at the Rotax course
I recently took. They said it is likely the check valve, as Eric says. I
remember they said you can take it apart and clean it, also inspect for
slight imperfections where the ball seats in it's "socket", which you
can do some lapping on to improve the seal.
Kevin
Europa XS Mono-Wheel
Inter-cooled Rotax 914
Airmaster Prop
On Mon, May 18, 2009 at 6:33 PM , Erich Trombley wrote:
Quote: |
<erichdtrombley(at)juno.com>
Paul,
Good luck,
Erich Trombley
min there
is soaked
never
appears that
filter
there was
Paul
Ivor Phillips
Posted: Tue May 19, 2009 9:37 am Post subject: oil leak |
As Eric said a sticking check valve is more likely the problem,
Mine did the same on first startup then run fine for 120 hours,
After the winter lay off its first startup this year was very similar but with less oil leaking, i have done another 20 hours with no more problems,
regards
Ivor
---- Erich Trombley <erichdtrombley(at)juno.com> wrote:
Quote: |
Paul,
Good luck,
Erich Trombley
Paul
