Stuck Oil Filter
CDE2fly(at)aol.com
PostPosted: Sun May 17, 2009 5:42 pm    Post subject: Stuck Oil Filter Reply with quote
Can someone verify if the Rotax 912S oil filter is a standard thread (clockwise to tighten)? Getting ready for the first start and can't get the darn oil filter off to purge the oil system. It's now clearly into the "need a new filter" stage as I've bent/punctured/mangled it trying to get it off. Tried PB Blast where the filter contacts the engine and it's just not budging...any ideas...tourch/heat???
Chris
Soon to be flying Series 7/9129S
A strong credit score is 700 or above. See Yours in Just 2 Easy Steps!
Roger Lee
PostPosted: Sun May 17, 2009 6:35 pm    Post subject: Re: Stuck Oil Filter Reply with quote
left will loosen and right tighten. You may need a set of the oil filter channel lock type pliers that have a set of sharp teeth to get a good grip. It will come off to the left. You need the pliers to grip it around the base metal ring.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
lcfitt(at)sbcglobal.net
PostPosted: Sun May 17, 2009 6:53 pm    Post subject: Stuck Oil Filter Reply with quote
Chris,
The thread is standard. I have always had to use one of the filter wrench
attachments that fit into a socket wrench type breaker bar - usually after
tapping it onto the end of the filter. From what you say, you may be passed
that point as that tool will only fit on the end of an undamaged filter.
The rim of the filter is heavy gauge steel and if you can get a pipe wrench
or channel locks on that without damaging anything, that should work.
Others might have other ideas.
Regarding purging the oil system. This is usually done after an oil change
to purge any air that might have been introduced into the system during the
oil change especially if the filter is changed or the magnetic plug is
removed for inspection. You will want to pressurize the tank per the
instructions after you remove the damaged filter and replace it with the new
one. During the purging process, the only open lines will be where the
compressed air is introduced - the oil tank, and where the oil will
eventually drain into a catch basin or bottle - the oil return line to the
tank.
Lowell
CDE2fly(at)aol.com
PostPosted: Sun May 17, 2009 7:23 pm    Post subject: Stuck Oil Filter Reply with quote
Thanks Lowell - I'll try the pipe wrench and let you know how it goes.
In a message dated 5/17/2009 10:54:24 P.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
[quote]--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Chris,
tank.
Lowell
darinh
PostPosted: Sun May 17, 2009 8:40 pm    Post subject: Re: Stuck Oil Filter Reply with quote
lcfitt(at)sbcglobal.net wrote:
Chris,
...Regarding purging the oil system. This is usually done after an oil change
removed for inspection...
Lowell,
According to Rotax-Owner.com you do not need to purge the oil system after you do a simple oil change. Basically if you work on the suction side of the system, you will need to purge the system. Yes, the tank is on the suction side but as long as you don't remove the tank and drain the suction line, you don't need to purge it. I have attached a Technical Article from the site for anyones information. It does a good job of describing the oils system, the SI's that have been put out by Rotax and examples of when oil purging is required. Take it for what it is worth but this is what they have to say about purging and oil changes. I personally have purged my system after each oil change but to be quite honest, I have never had a situation where the lifters had air in the either before or after the oil change.
ROTAX 9 series Oil Change.pdf
 Filename:  ROTAX 9 series Oil Change.pdf
 Filesize:  98.22 KB
 Downloaded:  4335 Time(s)
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
Dick Maddux
PostPosted: Mon May 18, 2009 5:42 am    Post subject: Stuck Oil Filter Reply with quote
Speaking of a stuck oil filter,during my last oil change I had something quite different. I knew they could be a bugger to get off so I fitted my oil filter removal tool but noticed the filter moved before I even got the tool on ! The filter then spun off in my hand with no effort at all ! That would have been a mess in flight if it spun itself off ! Quite likely ,would have ruined my day!
I tightened it down per the factory instructions when I did the prior oil change. I had the instructions right in front of me and followed it to the letter (including the engine run and filter tighten check) I told Dean at Lockwood about this and he said I was one of two people he had heard of this happening to.
Well once is enough so I have installed a large hose clamp around the filter (lined with rubber-Adel clamp like) and have safety wired the clamp to the engine so the filter won't move (also torque marked it)
          Dick Maddux
          Fox 4-1200
          912 UL
          Pensacola,Fl
A Good Credit Score is 70001367178/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=115%26bcd=Mayfooter51809NO115>See Yours in Just 2 Easy Steps!
PostPosted: Mon May 18, 2009 7:14 am    Post subject: Stuck Oil Filter Reply with quote
Darin,
I appreciate the heads-up on this. I have not been aware of the information
you mention. My thinking is that when removing the oil filter and the
magnetic plug, oil will drain and the oil draining out of the engine at
those points will result in something replacing the volumn of oil lost.
This - most likely air. I guess if you are really quick, the air introduced
will not be problematic.
Also, when I changed the oil, I would use a vacuum drain apparatus that
would suck the tank dry, I would then open the tank and wipe it out - this
would be on the suction side. There was always a lot of silvery sludge
there after one of the AVGas use periods. If I were to make a guess here,
it would be that Rotax found that with the engines that were merely drained
and refilled, like everything else out there, the no purging idea might be
good for business, i.e. less complexity.
I suppose with the new build, I will purge just like the old days.
What I was trying to suggest in my original post was essentially that
removeing the oil filter is not part of the purging process.
Lowell
Lynn Matteson
PostPosted: Mon May 18, 2009 9:21 am    Post subject: Stuck Oil Filter Reply with quote
Before I ever started my Jabiru, I used structural adhesive to attach
a 4-leaf clover-type device to the top of the filter like the big
boys do, and safety wired it. Since then, the filters have been so
well secured, that I haven't bothered with any kind of securing other
than to make sure that I give it one turn beyond gasket contact, per
the Baldwin filter B33 instructions....so far, so good, with around
20-24 filter changes.
Lynn Matteson
Jabiru 2200, #2062, 655.4 hrs
Sensenich 62x46 Wood prop
Status: flying
marked it)
Dick Maddux
Fox
4-1200
912 UL
Pensacola,Fl
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
CDE2fly(at)aol.com
PostPosted: Mon May 18, 2009 5:08 pm    Post subject: Stuck Oil Filter Reply with quote
Lowell - I'm happy to report that the pipe wrench suggestion worked like a charm! In less than a minute on my way out the door for work this morning the filter was successfully removed - a pleasant alternative to the hour plus spent last night trying to mangle it off...
The reason I was trying to remove it was to follow the instructions in the HomebuiltHelp video with regards to first start procedures. The video advises adding three quarts of oil to the tank then pulling the prop through numerous rotations while adding oil to oil line marked "out" via a funnel until oil discharges from the oil filter port (with the filter off) to purge air from the oil system.
In a message dated 5/18/2009 11:15:30 A.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
Darin,
Lowell
