r-stout(at)hotmail.com Guest
Posted: Sun May 17, 2009 9:34 am Post subject: VDO gauges |
I have installed a Rotax 912 ULS in a Highlander and have used VDO oil pressure and oil Temp. gauges. I have connected the + and - and the sender wire, as shown on the wiring diagram, but I am showing a ground short between all the pins and the power buss bar. Has anyone else run into that problem or can Bob shed some light on the problem? I've run out of ideas, and I haven't talked to anyone else that knows anything about the problem. Any help would be appreciated.
Roger
Best way to e-mail me is at R-Stout(at)Hotmail.com (R-Stout(at)Hotmail.com)
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rampil
Posted: Thu Jun 04, 2009 8:59 am Post subject: Re: VDO gauges |
Roger,
You did not mention why you did this resistance check in the first place.
What meter problem did you have?
The meter is supposed to measure the resistance of the probe using the
supply voltage. An R check of the meter itself might be meaningless
Ira
