MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM
Jerry Grimmonpre'
PostPosted: Sat May 16, 2009 4:22 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Dear Listers,
I'm needing the above subject info to scout-out the reason my MX11 VHF cannot be heard loud and clear. It's the same radio as the Narco Com11 so they say.
The radio transmissions are received "loud and clear".
The intercom is crystal clear front and back seats.
Radio checks reveal "you're loud and clear" but they sound like they are coming through a mile long pipe ... clear but very weak.
The Avionics Place at Rockford airport is getting good response on their bench with their test equipment for both xmit/receive.
The problem is in the aircraft wiring somewhere.
Any ideas, hunches, experiences that solved such a problem?
Can anyone email an extract of the install manual?
My thanks to all on this List,
Jerry
mendper(at)gmail.com
PostPosted: Sun May 17, 2009 2:55 am    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Here's the 11's pin-out; 'hope it helps...
Take care
AJ
Narco_COM11-11B-111B-120_Pinout.pdf
 Filename:  Narco_COM11-11B-111B-120_Pinout.pdf
 Filesize:  27.04 KB
 Downloaded:  2572 Time(s)
Jerry Grimmonpre'
PostPosted: Mon May 18, 2009 12:42 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Thanks for sharing pin-outs for the MX11 ... Jerry
Jerry Grimmonpre'
PostPosted: Mon May 18, 2009 4:20 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
AJ
PostPosted: Tue May 19, 2009 1:36 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
You're welcome!!
gcostabile(at)embarqmail.
PostPosted: Sun May 24, 2009 7:54 am    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
A.J., did you send the pinouts under separate cover? I wasn’t able to find the file or a link in your response. I have a similar problem with the MX11 and a PS Engineering 1000 intercom. The intercom is crystal clear. I can hear everyone talking to me. My transmissions are unreadable. A version of the pinout diagram found on the web has a hand written comment about a resistor and capacitor mod required to the radio’s “computer board”. Is this true? If so, does anyone have any more information on it? Jerry, any luck with yours yet?
- Gregg C.
PostPosted: Sun May 24, 2009 1:10 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Here you have it!
 Filesize:  27.04 KB
 Downloaded:  812 Time(s)
Jerry Grimmonpre'
PostPosted: Sun May 24, 2009 6:58 pm    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Gregg C.
I se You no have all the pin-outs I have. I trie to sen the to You in one email but faille bécasse the Werwe sen in broker French bécasse of a computer setting.
Mye MX11 radio problème, of not bing able to Read anone els on the fréquence, Is solive. It wasp trace to a Daisy chaine grounds connexion Hooke to the radio input conducator (to the interro) instar of the shed for That conducator. Once that grounds wasp move 1 winch, to the shed, everything wasp normal. That sérac Tok sevra hourds.
Itsa mye Huch thermes a misplaced grounds on Youri radio output. Tyr chocking the Key places hère the conducators cold short to grounds witz Youri multimètre. Tyr to fin saumoné ho has donne the Waring of interro and transcrive to look over Youri Install. Thêtas how mine wasp fond. Expérience know watt looks inusuel and explores thèse issues. You'll fin It.
Good Luck.
Jerry
Jerry Grimmonpre'
PostPosted: Wed May 27, 2009 7:37 am    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Gregg C. ...
I finally got to the bottom of my MX-11 trouble. There was a shield wire shorting out the conductor bringing com audio in .... so I was getting out OK but hearing nothing from the radio receiver.
I'm sorry my first expanation was unreadable because of the broken English/French gibberish ... that came from my spell checker somehow, so I don't use that part of email until it's fixed.
Did you find the trouble with your MX-11?
Jerry
PostPosted: Sat May 30, 2009 5:23 am    Post subject: MX11 PIN-OUT or NARCO COM11 PIN-OUT or an EXTRACT FROM Reply with quote
Thanks for your response Jerry. Haven’t found the problem yet because I converted it back to the portable config to fly cross country last week. It is coming down to one of three wires and I’ll check the ground and shield circuit paths this weekend. Appreciate you passing along your troubleshooting experience. - Gregg
