orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Deems Davis
Posted: Fri May 15, 2009 6:05 pm Post subject: Upper intersection leg fairing |
I built them up with additional layers of glass before fitting to the
fuse. here's a link to a photo album:
http://deemsrv10.com/album/Sec%2048%20Gear%20Leg%20&%20Wheel%20Fairings/slides/DSC03905.html
follow the links on the left of the page to additional pictures.
Here's links to the build log:
http://deemsrv10.com/48-10&48-11.htm
http://deemsrv10.com/48-11&48-12.htm
I later decided to attach the lower intersection fairings directly to
the wheel pants, Additional pictures:
http://deemsrv10.com/album/Sec%2048%20Gear%20Leg%20&%20Wheel%20Fairings/slides/DSC04260.html
Note: I haven't installed these on the 'finished; aircraft yet
Deems
N519PJ 16.5 hrs
orchidman wrote:
I can't find any comments on Tim's or Deems site about how you construct the upper leg intersection fairing.
Are you applying the 2 layers of glass to each one? If so, are you doing it on the plane? If so, how are you holding it to the fuselage while applying the glass?
I have trimmed the fairings and drilled the 4 holes and clecoed them to the fuselage. I am happy so far. Now how do you add the glass while the clecos are holding the fairing in place? [Shocked]
Gary Blankenbiller
RV10 - # 40674
Final Finishing - SB
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p 44232#244232
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Fri May 15, 2009 9:40 pm Post subject: Upper intersection leg fairing |
I didn't like the way the Van's uppers fit, so we built our own.
Make sure you max the tape prior to applying the glass.
Don McDonald
--- On Fri, 5/15/09, orchidman <gary(at)wingscc.com> wrote:
Subject: Upper intersection leg fairing
Date: Friday, May 15, 2009, 6:11 PM
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
Gary Blankenbiller
RV10 - # 40674
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=244232#24423om/Navigator?RV10-List" target=_blank>http://www.matronics.com/Navigator? - MATRONICS WEB FORUM; -Matt Dralle, List Admin==========
245.5 KB |
4443 Time(s) |
370.32 KB |
4443 Time(s) |
197.3 KB |
4443 Time(s) |
_________________ Don A. McDonald
40636 |
Mike Whisky
Posted: Fri May 15, 2009 10:39 pm Post subject: Re: Upper intersection leg fairing |
Hi Don,
what is the name of the blue stuff that you used to model the fairing with?
Michael
_________________ RV-10 builder (flying)
#511 |
partner14
Posted: Sat May 16, 2009 5:33 am Post subject: Upper intersection leg fairing |
Clay...... wife bought it at Michael's. Easy to form, not as easy to get it all off.... but that doesn't matter much.... after you get off what you can, use a heat gun.... but don't burn the glass.... it kind of rolls right off.
Don
40636 |
orchidman
Posted: Sat May 16, 2009 8:50 am Post subject: Upper intersection leg fairing |
You can also get blue foam insulation from Lowes or other building
supply places. My Home Depot didn't have it. It's messy, but I think
it'll dissolve with gasoline.
Linn
Don McDonald wrote:
| Quote: | Clay...... wife bought it at Michael's. Easy to form, not as easy to
rolls right off.
Don
--- On *Fri, 5/15/09, Michael Wellenzohn /<rv-10(at)wellenzohn.net>/* wrote:
Subject: Re: Upper intersection leg fairing
Date: Friday, May 15, 2009, 11:39 PM
<http://us.mc01g.mail.yahoo.com/mc/compose?to=rv-10(at)wellenzohn.net>>
Hi Don,
fairing with?
Michael
RV-10 builder (engine, prop, finishing)
#511
<http://forums.matronics.com/viewtopic.php?p 44246#244246>ht="http://forums.matronics.com/"
target=_blank>http://forums.matronics.c
&nbsf="http://www.matronics.com/contribution" =======
<http://www.matronics.com/Navigator?RV10-List>
Checked by AVG - www.avg.com
