mosquito56
Posted: Fri May 15, 2009 8:54 am Post subject: Marking Wires? |
I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon.
Can anyone suggest a method to print on shrink sleeving if possible? I have no idea what one would be called.
I had heard there was a way to use a laser printer to do this in some way also.
Any other ideas would be welcome.
Don
_________________ Don Merritt- Laredo, Tx
jaybannist(at)cs.com Guest
Posted: Fri May 15, 2009 9:34 am Post subject: Marking Wires? |
Don,
I used a laser printer with Arial 7 point type, all caps to make labels. I would have 4 lines, aligned one below the other. I cut these labels out, rolled them around the wire, slipped clear tubing over the paper and heat shrunk it. I labeled both ends of each wire. I labeled the first end at the first terminal at my shop bench. The other end would wait until I knew the wire length to the second terminal. That was usually in the airplane, just before I installed the final terminal connector. Experience tells me that adequate labeling is an absolute necessity.
Jay Bannister
davidbowman1(at)verizon.n Guest
Posted: Fri May 15, 2009 9:44 am Post subject: Marking Wires? |
you can use a Kroy TubeMarker. It will print on shrink tubing. Look at
alliedelec.com
Dave-Westlake Village, CA
bob(at)bob-white.com Guest
Posted: Fri May 15, 2009 9:46 am Post subject: Marking Wires? |
Hi Don,
If you wanted a whole lot of labels with the same marking, I've used
Merithian Products Corp. http://www.merithian.com/
For small quantities, printing on white heat shrink tubing with a fine
point Sharpie a good job.
Bob W.
On Fri, 15 May 2009 09:54:07 -0700
"mosquito56" <mosquito-56(at)hotmail.com> wrote:
Don
Apologies if I seem antagonistic.
I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life.
http://forums.matronics.com/viewtopic.php?p 44167#244167
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/
Posted: Fri May 15, 2009 10:03 am Post subject: Marking Wires? |
Hi Don,
After much frustrated wrapping and securing laser printed name tabs, I
found wrapping the wire 180-degrees with packaging tape
and placing the name tab between the extended adhesive ends, the loose
protected name tab is easier to read than one coaxial with
the wire. It's also much easier to do. Just don't go overboard on the
marking if it's obvious what the wire's for.
mosquito56 wrote:
Don
Bruce(at)glasair.org Guest
Posted: Fri May 15, 2009 10:25 am Post subject: Marking Wires? |
Check Ebay for Kroy first.
Bruce
www.Glasair.org
kesleyelectric(at)chooseb Guest
Posted: Fri May 15, 2009 11:25 am Post subject: Marking Wires? |
Don,
I ended up buying a RhinoPro 5000, which I am very happy with. It will also
print on heatshrink tubing. See link below.
http://www.ecomofficesupplies.com/ProductInfo~productid~DYM15603.html#
These folks have good service and very reasonable shipping for refill
supplies.
Just a quick plug here. Our EAA chapter, Chapter 94 in Mason City, IA, is
sponsoring an Aero Electric Seminar on June 27-28. Refer to Bob's website
for details. The hanger is a great facility located right off the taxiway
for easy flying or driving. There will be a Saturday evening cookout, should
be a great time. Hope to see some of you there.
Tom Barter
Kesley Electric, Inc.
BobsV35B(at)aol.com Guest
Posted: Sun May 17, 2009 3:54 pm Post subject: Marking Wires? |
Good Afternoon Don,
I borrowed a WWII vintage, hand operated, electric wire marker and printed a label about every ten inches on every wire I used. It probably caused me to waste a few feet of wire as I tended to make each wire just a bit longer than needed, but it sure helps a lot during the assembly and for trouble shooting.
Using any sort of shrink tube application darn near doubles the diameter of the small wires we tend to need. I tried that and did not care for the extra bulk at all.
If I had a very sophisticated airplane to wire, I would watch E-Bay and buy my own wire marking machine! If it's good enough for Boeing and Beechcraft, it's good enough for me!
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 5/15/2009 11:57:50 A.M. Central Daylight Time, mosquito-56(at)hotmail.com writes:
| Quote: | I am looking for a way to mark my wires in my Zodiac 601XL. I am just finishing up the body and will begin engine installation soon.
Don
A strong credit score is 700 or above. See Yours in Just 2 Easy Steps!
scott(at)n696js.com Guest
Posted: Tue May 19, 2009 8:27 am Post subject: Marking Wires? |
I did exactly what Jay described here. For some of the smaller wire runs (20-22AWG) I actually used 2 pieces of heat shrink. The first I would shrink on to give the wire some girth, then I would slip on my label and shrink on another piece to hold the label in place. It is working great so far.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
Sent: Friday, May 15, 2009 10:26
Subject: Re: AeroElectric-List: Marking Wires?
Don,
Jay Bannister
-----Original Message-----
Sent: Fri, 15 May 2009 11:54 am
Subject: Marking Wires? | Quote: | --> AeroElectric-List message posted by: "mosquito56" <mosquito-56(at)hotmail.com (mosquito-56(at)hotmail.com)>
Don
http://forums.matronics.com/viewtopic.php?p=244167#244167
size=2 width="100%" align=center>
Email message sent from CompuServe - visit us today at http://www.cs.com
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
ianxbrown
Posted: Tue May 19, 2009 9:18 am Post subject: Marking Wires? |
Having had very recent experience of this, just remember that the really
neat, shrunk on labels can be fiendishly difficult to read when you're
upside down, under the panel, on the tarmac. There is something to be
said for larger labels, or even a coded system and a lookup table.
Ian Brown
Flight testing RV-9A
On Tue, 2009-05-19 at 09:26 -0700, Scott R. Shook wrote:
[quote] I did exactly what Jay described here. For some of the smaller wire
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
______________________________________________________________________
From:owner-aeroelectric-list-server(at)matronics.com
Subject: Re: Marking Wires?
Don,
Jay Bannister
Posted: Tue May 19, 2009 9:34 am Post subject: Marking Wires? |
Good Afternoon Ian,
I find that one of the advantages to marking directly on the wires such as the big boys do is that if I can't read the label in one spot, there is a good chance I will be able to read it within a foot or two of the termination point.
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 5/19/2009 12:20:34 P.M. Central Daylight Time, ixb(at)videotron.ca writes:
| Quote: | Having had very recent experience of this, just remember that the really
Ian Brown
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
A simple and low cost way to mark wires is to use wire number markers (1/4” x 1 ¼”) lengthwise on each end of the wire and then put heat shrink over it. The only down side is that you have to keep a chart showing what each wire number is for. See:
http://cableorganizer.com/wire-marker/#features
Joe R
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook
Sent: Tuesday, May 19, 2009 10:27 AM
Subject: RE: Marking Wires?
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Don,
Jay Bannister
Posted: Tue May 19, 2009 9:47 am Post subject: Marking Wires? |
At 12:29 PM 5/19/2009, you wrote:
| Quote: | A simple and low cost way to mark wires is to
Before you spend a lot of $time$ putting numbers
on individual wires, think through the expected return
on investment. While the wires are waiting to be tied
off, a masking tape flag with a sharpie notation of
where it goes will get you done.
Now, what is the likelihood that you'll benefit from
the existence of ANY single wire marking at some
time in the future? When you're working with 3"
wire bundles of hundreds of wires, yeah . . . but
the future maintenance value of individual wire marking
is of limited value in a single engine airplane. But
if you must . . .
B&C still sells the clear heat-shrink kit I used
to offer for marking wires like this:
http://aeroelectric.com/Pictures/Wiring_Technique/Wire_Marking.jpg
You can print columns of labels in 6pt type on
full sheets of label material. Pull of the backing
sheet, paste to a plastic cutting board. Use x-acto
knife to cut out label of interest and attach to
wire with clear shrink.
( -Thomas Paine 1776- )
jay(at)horriblehyde.com Guest
Posted: Wed May 20, 2009 1:08 am Post subject: Marking Wires? |
Jay's think alike- I did the same as Jay Bannister except that I used a sharpie to write onto strips of white plastic that I had cut from a square shaped milk container. The surface of the plastic is slightly rough so that you can easily write on it. The advantage for me was that I didn't have to jump between the PC and the shop. The plastic was about 0.6mm thick and I cut it into strips about 4mm high. This also meant that it was often bigger than the wire which allowed you (with a bit of a tug) to slide the label and clear shrink up and down the wire to where you wanted it as the plastic slightly held the heat shrink off the wire except at the ends.
Of course you have to be able to print neatly...
Jay Hyde
