JetPilot
Posted: Wed May 13, 2009 4:55 am Post subject: Kiev Hot Prop And Spacer For Sale - Almost New |
I am selling my Kiev Hot prop that I had on my Kolb for the first 25 hours or so. The prop includes a 4 inch spacer, all mounting hardware for a Rotax 912-S, has nickel leading edges, is black in color, and is in good condition. The prop was very smooth on my Kolb and performed well, I changed it to a solid Warp Drive because I am concerned about the light construction of the Kiev and what would happen if something went through the prop. I am going to ask 800 dollars for this prop. I paid something like 1250 for everything new. Attached are some pictures when it was on my Kolb.
Mike
| Description: |
| Filesize: |
394.19 KB |
| Viewed: |
2067 Time(s) |
| Description: |
| Filesize: |
340.19 KB |
| Viewed: |
2067 Time(s) |
| Description: |
| Filesize: |
354.03 KB |
| Viewed: |
2067 Time(s) |
| Description: |
| Filesize: |
325.1 KB |
| Viewed: |
2067 Time(s) |
Kolb MK-III Xtra, 912-S |
