craigtxtx(at)yahoo.com Guest
Posted: Mon May 11, 2009 3:34 pm Post subject: Air Ramp Cracking |
After a mere 60 hours TT I have noticed cracks around rivets on the F867 air ramp on my RV8A. The cracks are at the outboard rivets that attach the air ramp to the center F867D stiffener. I suspect there is a lot of vibration from the engine exhaust pipes that end just about in that area. I have the standard Vetterman exhaust bought through Vans and after about 20 hours or so I added a set of 20 degree turndown exhaust extensions from Vetterman. The extensions seemed to help overall noise and vibration in the cockpit, but obviously there is still a significant amount of vibration causing the ramp to crack. It looks like I'll have to replace the ramp, but that is not addressing the root cause of the problem.
Has anyone else seen and solved this problem? Additional stiffeners on the air ramp? Longer exhaust extensions? Any help would be appreciated
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rv8a2001(at)yahoo.com Guest
Posted: Mon May 11, 2009 3:52 pm Post subject: Air Ramp Cracking |
I just sheered a piece of stainless and popped it in place. Oh I also bonded it with Pro-seal to hopefulle stop any vibration. It runs the full length and width of the exhaust ramp Its a simple fix that actually looks good with no paint.
Scott
--- On Mon, 5/11/09, Craig Gallenbach <craigtxtx(at)yahoo.com> wrote:
| Quote: | From: Craig Gallenbach <craigtxtx(at)yahoo.com>
Subject: Air Ramp Cracking
To: rv8-list(at)matronics.com
Date: Monday, May 11, 2009, 4:33 PM
extensions? Any help would be appreciated.
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Larry Bowen
Posted: Mon May 11, 2009 4:11 pm Post subject: Air Ramp Cracking |
I had the piccolo type extensions on mine. Good sound and no cracks in
365 hours. Otherwise ramps were stock.
On 5/11/09, scott bilinski <rv8a2001(at)yahoo.com> wrote:
no paint.
Scott
> Thanks in advance.
> Craig Gallenbach
> Eastover, NC
> RV8A N184CG 60 hrs.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Mon May 11, 2009 4:31 pm Post subject: Air Ramp Cracking |
Larry,
Where did you get the piccolo extensions?
Craig
no paint.
Scott
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Larry Bowen
Posted: Mon May 11, 2009 4:33 pm Post subject: Air Ramp Cracking |
Strongly agree on using pro-seal around the edges of the ramp. It reduces
vibration and seals oil and such from inside of the double floor.
Carl Froehlich
RV-8A (475 hrs)
RV-10 (fuselage)
Larry Bowen
Posted: Mon May 11, 2009 4:38 pm Post subject: Air Ramp Cracking |
They were the straight ones from Wicks:
http://wicksaircraft.com/catalog/product_search_results.php/search=cGljY29sbw==
I also had the edges prosealed, per the plans I think.
Larry Bowen
Sent from Welcome, NC, United States
On Mon, May 11, 2009 at 8:28 PM, Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)> wrote:
[quote] --> RV8-List message posted by: Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)>
Larry,
Craig
On May 11, 2009, at 8:10 PM, Larry Bowen <larry(at)bowenaero.com (larry(at)bowenaero.com)> wrote:
--> RV8-List message posted by: Larry Bowen <larry(at)bowenaero.com (larry(at)bowenaero.com)>
On 5/11/09, scott bilinski <rv8a2001(at)yahoo.com (rv8a2001(at)yahoo.com)> wrote:
--> RV8-List message posted by: scott bilinski <rv8a2001(at)yahoo.com (rv8a2001(at)yahoo.com)>
no paint.
Scott
--- On Mon, 5/11/09, Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)> wrote:
From: Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)>
To: rv8-list(at)matronics.com (rv8-list(at)matronics.com)
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Larry Bowen
rget="_blank">http://www.matronics.com/Navigator?RV8-List
http://forums.matronics.com
le, List Admin.
RV-8 SOLD,
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27562 Location: Livermore CA USA
Posted: Mon May 11, 2009 5:11 pm Post subject: Air Ramp Cracking |
ACS says "3db" noise reduction, but I wonder what HP reduction? Those look pretty restrictive...?
At 05:37 PM 5/11/2009 Monday, you wrote:
| Quote: | They were the straight ones from Wicks:
<http://wicksaircraft.com/catalog/product_search_results.php/search=cGljY29sbw==>http://wicksaircraft.com/catalog/product_search_results.php/search=cGljY29sbw==
Larry Bowen
<http://BowenAero.com>http://BowenAero.com
On Mon, May 11, 2009 at 8:28 PM, Craig Gallenbach <<mailto:craigtxtx(at)yahoo.com>craigtxtx(at)yahoo.com> wrote:
Larry,
Craig
On May 11, 2009, at 8:10 PM, Larry Bowen <<mailto:larry(at)bowenaero.com>larry(at)bowenaero.com> wrote:
On 5/11/09, scott bilinski <<mailto:rv8a2001(at)yahoo.com>rv8a2001(at)yahoo.com> wrote:
_________________ Matt Dralle
Posted: Mon May 11, 2009 5:24 pm Post subject: Air Ramp Cracking |
Duh, I meant "Wicks".
At 06:06 PM 5/11/2009 Monday, you wrote:
>Larry Bowen
>Larry,
>Craig
>Sent from my iPhone
Larry Bowen
Posted: Mon May 11, 2009 5:41 pm Post subject: Air Ramp Cracking |
I gained 10 knots and fuel burn decreased 1.5 ghp. Just kidding. I put them on early, and never got around to testing. I had typical RV-8 speed numbers and had no problem keeping up with the others, so if there was a HP loss it was negligible, IMO.
Larry Bowen
On Mon, May 11, 2009 at 9:06 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
[quote] --> RV8-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
>Larry Bowen
>Larry,
>Craig
>Sent from my iPhone
>--> RV8-List message posted by: Larry Bowen <<mailto:larry(at)bowenaero.com (larry(at)bowenaero.com)>larry(at)bowenaero.com (larry(at)bowenaero.com)>
le, List Admin.
RV-8 SOLD,
Posted: Tue May 12, 2009 1:51 am Post subject: Air Ramp Cracking |
Thanks Scott. How long has that fix been working?
Craig
Scott
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Posted: Tue May 12, 2009 5:14 am Post subject: Air Ramp Cracking |
| Quote: | From day one I heard about this problem and "fixed" it before first flight. So that would be almost 700hrs now.
Scott
RV-8a
Subject: Re: Air Ramp Cracking
To: "rv8-list(at)matronics.com" <rv8-list(at)matronics.com>
Date: Tuesday, May 12, 2009, 2:50 AM
Craig
paint.
Scott
exhaust
exhaust
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
breece28117(at)yahoo.com Guest
Posted: Tue May 12, 2009 1:52 pm Post subject: Air Ramp Cracking |
This is the first time I've heard of this problem. Where can I find more info? I have just installed a 200hp Lycoming, Vetterman crossover exhaust system and CS prop on my nearly-finished RV-8.
Breece Nesbitt
Mooresville, NC
Sent: Tuesday, May 12, 2009 8:54:06 AM
Scott
RV-8a
--- On Tue, 5/12/09, Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)> wrote:
| Quote: | From: Craig Gallenbach <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)>
To: "rv8-list(at)matronics.com (rv8-list(at)matronics.com)" <rv8-list(at)matronics.com (rv8-list(at)matronics.com)>
Craig
On May 11, 2009, at 7:52 PM, scott bilinski <rv8a2001(at)yahoo.com (rv8a2001(at)yahoo.com)>
paint.
Scott
exhaust
exhaust
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Forum -
FAQ,
-Matt
Dralle, List Admin.
Posted: Tue May 12, 2009 3:45 pm Post subject: Air Ramp Cracking |
Probably not on this E-mail list but if you do a search on the larger lists I am sure it will come up.
Adding a doubler, in my case stainless, is so easy to do especially when building why not just do it. At least that's my thinking.
Scott
RV-8a
--- On Tue, 5/12/09, Breece Nesbitt <breece28117(at)yahoo.com> wrote:
| Quote: | From: Breece Nesbitt <breece28117(at)yahoo.com>
Date: Tuesday, May 12, 2009, 2:46 PM
Breece Nesbitt
Mooresville, NC
To:
Sent:
Subject: Re:
Air Ramp Cracking
almost 700hrs now.
Scott
RV-8a
> Craig
> Sent from my iPhone
place.
any
exhaust
no
> paint.
> Scott
PM
my
that
stiffener. I
> exhaust
the
after
turndown
significant
It
is
> Additional
> exhaust
> Thanks in advance.
> Craig Gallenbach
> Eastover, NC
> RV8A N184CG 60 hrs.
> Forum -
> FAQ,
-Matt
> Dralle, List Admin.
Posted: Tue May 12, 2009 5:36 pm Post subject: Air Ramp Cracking |
Thanks, Scott. I'll do some research.
Breece
RV-8
Sent: Tuesday, May 12, 2009 7:43:13 PM
Scott
RV-8a
--- On Tue, 5/12/09, Breece Nesbitt <breece28117(at)yahoo.com (breece28117(at)yahoo.com)> wrote:
| Quote: | From: Breece Nesbitt <breece28117(at)yahoo.com (breece28117(at)yahoo.com)>
Breece Nesbitt
Mooresville, NC
To:
Sent:
Subject: Re:
Air Ramp Cracking
almost 700hrs now.
Scott
RV-8a
> Craig
> Sent from my iPhone
place.
any
exhaust
no
> paint.
> Scott
PM
my
that
stiffener. I
> exhaust
the
after
turndown
significant
It
is
> Additional
> exhaust
> Thanks in advance.
> Craig Gallenbach
> Eastover, NC
> RV8A N184CG 60 hrs.
> Forum -
> FAQ,
-Matt
> Dralle, List Admin.
nbsp; =======================
Posted: Tue May 12, 2009 7:12 pm Post subject: Air Ramp Cracking |
Scott,
Did you modify your exhaust outlet in any way as well? Thanks,
Craig
Scott
RV-8a
Breece Nesbitt
Mooresville, NC
To:
Sent:
Subject: Re:
Air Ramp Cracking
almost 700hrs now.
Scott
RV-8a
Craig
place.
any
exhaust
no
paint.
Scott
PM
my
that
stiffener. I
exhaust
the
after
turndown
significant
It
is
Additional
exhaust
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Forum -
FAQ,
-Matt
Dralle, List Admin.
Posted: Wed May 13, 2009 4:14 am Post subject: Air Ramp Cracking |
No exhaust modifications, just a piece of stainless over the existing aluminum with Pro-seal, its that simple.
Scott Bilinski
RV-8a
Date: Tuesday, May 12, 2009, 8:09 PM
Scott,
well? Thanks,
Craig
my thinking.
Scott
RV-8a
on
Breece Nesbitt
Mooresville, NC
To:
Sent:
Subject: Re:
Air Ramp Cracking
almost 700hrs now.
Scott
RV-8a
Craig
place.
any
exhaust
no
paint.
Scott
PM
my
that
stiffener. I
exhaust
the
after
turndown
significant
It
is
Additional
exhaust
Thanks in advance.
Craig Gallenbach
Eastover, NC
RV8A N184CG 60 hrs.
Forum -
FAQ,
-Matt
Dralle, List Admin.
Forum -
FAQ,
-Matt
Dralle, List Admin.
