GPU - 24V System - Crowbar Needed
ChangDriver
PostPosted: Sun May 10, 2009 5:16 pm    Post subject: GPU - 24V System - Crowbar Needed Reply with quote
Bob:
The B&C OVM-14 is a 14 volt corwbar isn't it? For a 24 VDC system, what crowbar would I use for a GPU? Also, wouldn't an inline fuse be helpful as the crowbar basically provides a low resistance path to ground to bypass the contactor. Don't you need something to a fuse or breaker to protect the crowbar from excessive current?
Craig
PS - I'm working on a GPU for a 24V aircraft application.
PostPosted: Sun May 10, 2009 9:12 pm    Post subject: GPU - 24V System - Crowbar Needed Reply with quote
At 08:16 PM 5/10/2009, you wrote:
<capav8r(at)gmail.com>
Bob:
Yes. See
http://www.aeroelectric.com/PPS/DCPwr/Ground_Power/Ground_Power_1.pdf
and . . .
http://www.aeroelectric.com/PPS/DCPwr/Ground_Power/Ground_Power_D.pdf
The OVM-14 and our CbOVM-14 can be supplied in a
OVM-28 and/or CbOVM-28 versions.
( -Thomas Paine 1776- )
woxofswa
PostPosted: Mon May 11, 2009 10:38 am    Post subject: Re: GPU - 24V System - Crowbar Needed Reply with quote
Can I ask a neophyte question in the quest for further light and knowledge?
Why is a contactor, and/or switch needed for ground power?
It seems to me that the very act of plugging in the plug could serve as "activating" the power, and pulling the plug out would deactivate it.
What am I missing?
Myron Nelson
Mesa, AZ
Flew May 10 2014
Neal.George(at)hurlburt.a
PostPosted: Mon May 11, 2009 11:23 am    Post subject: GPU - 24V System - Crowbar Needed Reply with quote
Myron -
Switching the ground power connection allows the pilot full control of the
circuit. Over-voltage warning enhancements provide the opportunity to
monitor and verify that the lineboy has indeed plugged in 12v instead of 24v
- before you light up the internal circuits.
Neal
What am I missing?
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.04 KB
 Downloaded:  465 Time(s)
PostPosted: Mon May 11, 2009 1:22 pm    Post subject: GPU - 24V System - Crowbar Needed Reply with quote
The implementation of ground power connectors
published on my website and discussed on the forums
grew out of the following design goals:
(1) protection from 28 volt ground power being applied
to a 14v airplane.
(2) pilot control of ground power from the left seat.
(3) reverse polarity protection.
(4) convenience of an industry-common connection to
the aircraft relatively free of hazard to ground
crew from spinning props.
Twice in my experience, I've had 28v connected to my
14v airplane. In one case, the line-boy caught the error
and flipped the switch before I could even react. In the
other case he couldn't hear me over the roar of the
ground power cart engine and he had his back to me
watching the gages on the cart. I had to unbuckle,
slide over, open r.h. cabin door and yell at him while
stuff in the airplane suffered.
Making and breaking a high current load during
mate/de-mate operations is hard on the connector.
But if you plan to exercise absolute and personal
control over how and under what conditions external
sources of power get hooked to your airplane, then
it might be as simple a task as hooking up the
jumper cables.
But standing in a stream of wet, wind-driven snow
this winter, I got a pair of jumper cables reversed
to my son's van . . . didn't hurt anything but it
sure COULD have. The degree of risk you're willing
to shoulder is up to you.
bicyclop(at)pacbell.net
PostPosted: Mon May 11, 2009 4:11 pm    Post subject: GPU - 24V System - Crowbar Needed Reply with quote
Besides keeping the wrong voltage from hitting your battery and buss, a
ground power contactor keeps the fat wire running to the receptacle from
being hot all the time and being a potential shorting hazard.
Pax,
Ed Holyoke
What am I missing?
Myron Nelson
Mesa, AZ
http://forums.matronics.com/viewtopic.php?p 43572#243572
woxofswa
PostPosted: Tue May 12, 2009 12:00 am    Post subject: Re: GPU - 24V System - Crowbar Needed Reply with quote
Thanks for the info guys.
I am going to do it the proper way and have already ordered the parts. I just like understanding the science as well
Myron Nelson
Mesa, AZ
Flew May 10 2014
