lacing tape
icubob(at)gmail.com
PostPosted: Sun May 10, 2009 3:21 am    Post subject: lacing tape Reply with quote
hi all,
 i decided to use ''lacing tape'' from acs for wirjng my wood wings. i will put a wrap of silocon tape on the wire first, then attach. price of lacing tape was reasonable so i have plenty to replace the plastic tie wraps in the engine compartment if they dont take the heat. thanks for all the input.
 bob noffs
kerrjohna(at)comcast.net
PostPosted: Sun May 10, 2009 5:55 am    Post subject: lacing tape Reply with quote
F16's and my Hatz Classic has the same method of securing wire bundles.
John Kerr
Kitfox Classic, 912ul
784 hours GLC
Lynn Matteson
PostPosted: Sun May 10, 2009 9:43 am    Post subject: lacing tape Reply with quote
Are you sure you want to subject lacing tape to the heat of the
engine compartment? I would test this tape under the same heat
conditions as under the cowl, before I committed to using it. The tie
wraps that I used...nothing special....hold up perfectly on my plane.
Lynn Matteson
Jabiru 2200, #2062, 647.4 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 10, 2009, at 7:20 AM, bob noffs wrote:
hi all,
bob noffs
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
lcfitt(at)sbcglobal.net
PostPosted: Sun May 10, 2009 11:13 am    Post subject: lacing tape Reply with quote
Lynn,
The lacing tape I used is polyester. We shrink our covering fabric to 350°.
I would sure hope that the wiring in the engine compartment won't get to
350°. At the temperatures that would degrade the polyester, I think I would
be more concerned about the fuel lines.
Lowell
Float Flyr
PostPosted: Sun May 10, 2009 2:38 pm    Post subject: lacing tape Reply with quote
While I don't like using tie wraps any where a person may be reaching into
they are far ahead of any adhesive unless you are planning on tying the
tapes as well. You need something mechanically sound both in the engine
compartment and in the wings. Mechanically sound means tie wraps or good
solid knots not any adhesive tape.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
icubob(at)gmail.com
PostPosted: Sun May 10, 2009 7:06 pm    Post subject: lacing tape Reply with quote
i believe the tape from acs was nylon. good or bad?
 bob noffs
On Sun, May 10, 2009 at 8:08 PM, Noel <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
[quote]--> Kitfox-List message posted by: "Noel" <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
Noel
Lynn Matteson
PostPosted: Mon May 11, 2009 2:21 am    Post subject: lacing tape Reply with quote
Gotcha...I was thinking about the waxed lacing tape that I used for
my rib lacing. I used it firewall rearward for wire bundles, and
plastic ties firewall forward.
Lynn Matteson
Status: flying
On May 10, 2009, at 3:00 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Lynn,
to 350°. I would sure hope that the wiring in the engine
compartment won't get to 350°. At the temperatures that would
degrade the polyester, I think I would be more concerned about the
fuel lines.
Lowell
Lynn
N369LM
Lynn Matteson
PostPosted: Mon May 11, 2009 2:23 am    Post subject: lacing tape Reply with quote
I learned a good trick while attending an EAA weekend electrical
course....cut the ties really close with a beveled snipper found at
electrical stores, and the *usually* sharp edges that you usually get
are no more.
Lynn Matteson
Status: flying
reaching into
the
engine
or good
Lynn
N369LM
Float Flyr
PostPosted: Mon May 11, 2009 5:51 am    Post subject: lacing tape Reply with quote
It’s not the tape it’s the adhesive that can weaken in the relative warm of the engine compartment. That is one of the reasons you will seldom if ever see a roll of electrical tape in an A&Ps tool box. Most adhesives can become soft and gooey with the heat the compartment can endure while sitting on the apron while you are having one of those famous $100.oo hamburgers.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of bob noffs
Sent: 11 May 2009 12:35 AM
Subject: Re: lacing tape
bob noffs
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Mon May 11, 2009 6:38 am    Post subject: lacing tape Reply with quote
You can also go over the ends with a couple of swipes with a piece of
sandpaper. Unfortunately most people just reach in with the sidecuts and
when they hear the click of the end cutting off that's as far as it goes. I
have the scars to prove it does happen. Like a lot of homebuilders who are
not under time constraints you no doubt take the time to make your trims
properly. Once gashed twice leery.
I like the Koroseal lacing cord. It keeps things nice and snug without
allowing any wearing of insulation. You can't be cut with it and the
chances of cutting a wire in a bundle while removing it are a lot lower.
Basically I use it like wax chord (tape, string etc.) in the engine
compartment.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Mon May 11, 2009 6:41 am    Post subject: lacing tape Reply with quote
Bob,
The tape comes in Nylon and Polyester. Consider that the tie wraps some are
recomending are nylon, I don't see a problem. I read a forum piece on
another site where one of the guys said he had tried them both and he
perferred Nylon. I personally don't think it makes any difference as far as
security goes. I use Polyester simply because a guy on this forum got a
hold of a lot of it surplus and offered it at a great price.
Lowell
Lynn Matteson
PostPosted: Mon May 11, 2009 10:07 am    Post subject: lacing tape Reply with quote
Yeah, I used to use every day side cutters, too, and often gashed
myself. Then I learned about the very small electronics snippers made
by Crescent. They don't bevel both sides of the cutting edge, just
one side. Thus you can cut right up close to the "fat" part of the
tie wrap, and all but eliminate any sharp edges.
I'll have to look into the Koroseal stuff.
Lynn Matteson
Status: flying
sidecuts and
goes. I
who are
trims
without
lower.
compartment.
Noel
Lynn
N369LM
Float Flyr
PostPosted: Mon May 11, 2009 11:42 am    Post subject: lacing tape Reply with quote
Nylon is a lot faster to install and it does give a good mechanical hold. That's not my beef with it... being sliced on several occasions is and of course those slices although not as deep as a knife blade would make they are a lot more painful and there is the slight matter of all the blood dripping everywhere.
I sure wish I'd seen the surplus sale.. The polyester can be a little on the dear side.
I’d love to see nylon ties do a clean job like this that you could pull a cloth over.
Noel
 Filesize:  54.86 KB
 Viewed:  14787 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
taildragon(at)msn.com
PostPosted: Mon May 11, 2009 6:40 pm    Post subject: lacing tape Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Has anyone tried Rescue Tape?
icubob(at)gmail.com
PostPosted: Tue May 12, 2009 3:08 am    Post subject: lacing tape Reply with quote
i use ''rescue tape'' around the wire before i secure it. i use it to protect the wire from chafing i wouldn't trust it asa fastener.
 bob noffs
On Mon, May 11, 2009 at 9:38 PM, Roger Standley <taildragon(at)msn.com (taildragon(at)msn.com)> wrote:
[quote] Has anyone tried Rescue Tape?
n85ae
PostPosted: Tue May 12, 2009 6:48 am    Post subject: Re: lacing tape Reply with quote
When I worked on planes in the Navy there were ONLY two wire bundle
materials. Lacing tape, and Adel clamps. That handles everything. We did
not ever use Nylon ties.
Jeff
(Ex Navy Aviation Electrician)
