leschampmd(at)aol.com Guest
Posted: Sat May 09, 2009 6:13 pm Post subject: Securing an RV-7 outboard leading edge |
I am building the wing of an RV-7A and need help on fastening the outboard leading edge ribs to the main spar. The job is obviously 2-man work, but how how those of you who have built this wing fastened those ribs to the spars? have you managed to use AN470-4 rivets and if so, how did you accomplish this? I ask the question because there is no room for a double offset cupped set to fit a rivet head. Have you used a special tool or modified the set? Have you used "pop" rived instead of solid ones? If, what rivets?
Bill
ceengland(at)bellsouth.ne Guest
Posted: Sat May 09, 2009 7:52 pm Post subject: Securing an RV-7 outboard leading edge |
leschampmd(at)aol.com wrote:
| Quote: | I am building the wing of an RV-7A and need help on fastening the
Bill
I had rotten luck with offset sets.
It's been a while since I did it, but if I remember correctly, I used a
long straight set & warped the rib to the side slightly. The
combination made room for the gun.
Charlie
chaskuss(at)yahoo.com Guest
Posted: Sun May 10, 2009 5:40 am Post subject: Securing an RV-7 outboard leading edge |
Bill,
I found that doing this job per Vans instructions to be pure idiocy! It's impossible for anyone (I'm 6'4" with long arms) to be able to accurately buck the rivets for the ribs in the center. I decided to use a different method. I back riveted these rivets in. I fabricated a special, heavy bucking bar for this.
This tool was designed to solve a difficult riveting problem on RV-7, RV-8/A & RV-9A models. On these models, the leading edge assembly is built in a cradle. It is then attached to the wing main spar by riveting the skins and rear flanges of the ribs to the main spar. Setting the 1/8" rivets between the inner L/E ribs and the main spar is extremely difficult to do well. I solved this by fabricating a large "Tim Allen" bucking bar. With this bar, these rivets can be "back riveted" in place.
I inserted the rivets from the front (top as viewed in the jig) to the rear of the wing cord. This is opposite of how Van has you set these rivets. I placed the "Tim Allen" bucking bar with the 1/8" universal set on top of the rivet. I then pressed down on the bucking bar. Fellow RV builder Eric Hensen set the shop heads from below (the rear) using the Avery back riveting set (part # 4580)
Since making this tool (about half an hour with a band saw and drill press) I've found numerous other areas to use it on my 8A. It is basically a piece of cold rolled steel 2" X 2" X 5" with 3 holes to insert your universal rivet sets in. I placed the holes so that I could move the rivet set around. This makes it easier to use the tool to set the end rivets on the leading edge ribs. I did cut a slight notch in the bar so that it would clear the "flange" around the lightening holes in the ribs. This notch allows me to hold the bar perfectly parallel to the rib web while using it.
These 3 holes are there to insert an 1/8" reduced size universal (Avery #1608) squeezer set in. (the ones you use in your Avery squeezer & C tool) The notch is 3/8" deep and 4" long. The 3 holes for the squeezer sets go in the un-notched area. The holes are 3/16" diameter. Make them deep enough to insert the squeezer sets.
Locate them so that the edge of the "reduced diameter" 1/8" universal set comes even with the edge(s) of the bar. Make the cut out area 4" long by 3/8" deep at the top end, away from the holes for the set. The 2 holes on the ends are to allow you to reach the rivets on the edges of the leading edge ribs. I wanted a lot of mass, so that the bar would keep the manufactured head tight against the W-809 rib flange during the back riveting process. To reach the 2 innermost ribs, you won't be able to exert a lot of downward force with your arm muscles. The extra weight (it's 3 pounds) really helps.
I also found this bar great for riveting the main ribs to the rear spar. I was able to install the manufactured heads against the
wing main rib flanges (keeping the manufactured head against the thinner material) rather than against the rear spar.
This method has 4 advantages as I see it.
#1)This method all but eliminates the chance (near certainty) of "tipping" the shop head of the rivets being set on the inner ribs. Using Van's method, the bucker can not see either the tail of the rivet or the surface of the bucking bar being held against it. He is trying to hold the bucking bar at almost arm's length to set the 2 center ribs. Many early RV-8 builders complained of it being extremely difficult to set these rivets without "tipping" them.
#2) Since you back rivet these rivets, the person using the gun can actually watch the shop head being formed. This makes it much easier to get excellent results.
#3)This method puts the manufactured head against the leading edge rib flange. This follows Mil-Spec recommendations. Van's method puts the shop head here where it is very hard to see (read impossible) while setting the rivet.
#4)Place some duct tape on the web of the main rib while back riveting these rivets. This will prevent any damage if the back rivet set slips.
Charlie Kuss
--- On Sat, 5/9/09, leschampmd(at)aol.com <leschampmd(at)aol.com> wrote:
| Quote: | From: leschampmd(at)aol.com <leschampmd(at)aol.com>
Subject: Securing an RV-7 outboard leading edge
To: rv-list(at)matronics.com
Date: Saturday, May 9, 2009, 9:59 PM
on?fastening the outboard leading edge ribs to the main
no room for a?double offset cupped set to fit a rivet head.
rivets?
Bill
13.78 KB |
6617 Time(s) |
10.89 KB |
6617 Time(s) |
58.59 KB |
6617 Time(s) |
53.53 KB |
6617 Time(s) |
Posted: Sun May 10, 2009 6:18 pm Post subject: Securing an RV-7 outboard leading edge |
Thanks to Charlie Kuss and Charlie England. I appreciate your advice on getting this leading edge in place.
Bill Leschampmd(at)aol.com (Leschampmd(at)aol.com)
Do not archive! We found the real 'Hotel California' and the 'Seinfeld' diner. What will you find? Explore WhereItsAt.com.
Posted: Sun May 10, 2009 6:44 pm Post subject: Securing an RV-7 outboard leading edge |
| Quote: | Thanks to Charlie Kuss and Charlie England. I appreciate your advice
Bill Leschampmd(at)aol.com <mailto:Leschampmd(at)aol.com>
Do not archive!
All the credit goes to the K, not the E. My 'rib warp' technique only
works on the main ribs; I forgot about the leading edge already being
assembled when you drop it on the spar....
Sorry 'bout that.
Charlie
kahamer(at)bigpond.net.au Guest
Posted: Sun May 10, 2009 8:13 pm Post subject: Securing an RV-7 outboard leading edge |
I used #6 plate nuts and srews.
Karl
Posted: Mon May 11, 2009 7:46 am Post subject: Securing an RV-7 outboard leading edge |
Bill,
I'm just "paying it forward". I received a LOT of help from the members of this list over the years. Does anyone know if the RV10 and RV12 wing designs are similar to the 7, 8 & 9A? I haven't worked on the wings of these two models (yet).
Charlie Kuss
Posted: Mon May 11, 2009 8:54 am Post subject: Securing an RV-7 outboard leading edge |
The -10 has the same joggle-rib architecture according to some of the drawings that I have seen. Hopefully, they added a sixteenth to the spacing so mere mortals can build them.....
Posted: Mon May 11, 2009 12:11 pm Post subject: Securing an RV-7 outboard leading edge |
| Quote: | Karl Ahamer - thanks for your suggestion to secure the leading edge on the RV-& wing.
It certainly sounds much easier than Vans's method. Another question - did you use
platenuts and #6 screws on each of the 5 holes, rib to spar?
Bill | We found the real 'Hotel California' and the 'Seinfeld' diner. What will you find? Explore WhereItsAt.com.
Posted: Mon May 11, 2009 1:49 pm Post subject: Securing an RV-7 outboard leading edge |
Hi Bill,
Can’t remember if I used them on all 5 holes,but some might be doable with rivets…..
I thought there are only 3 rivets per rib to main spar,but its been a few years now…
Karl
