cicrn(at)telus.net Guest
Posted: Fri May 08, 2009 9:45 pm Post subject: Standard L angle dimensions |
Hi,
The assembly manual refers to using some standard L angle aluminum. I
have looked through the plans, assembly manual, construction
standards but can't see what the dimensions are. Is it 20mm flanges x
0.025"? Or what? Thanks in advance.
Joe
750 Scratch Build
| - The Matronics Zenith750-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
Posted: Fri May 08, 2009 9:58 pm Post subject: Standard L angle dimensions |
I only have the 701 and 601XL plans but look on some of the first pages of
the plans. The width before bending (Developed Length) is 36 mm and is bent
from 0.025 inch sheet. Bend with a radius of 1/8th inch. They are generally
made across the full width of a 4 foot sheet so are called out with a length
of 1219 mm. I wrote an article on a simple press brake made out of 2 by 4s
and C-clamps for bending these if you want it. It was in the Zenith
newsletter a few issues ago.
-- Craig
Posted: Sun May 10, 2009 5:38 pm Post subject: Standard L angle dimensions |
Thanks Craig and Bruce!
For the life of me, I can't see where the dimensions are shown in the
plans. No matter, thanks to you guys, I will keep plodding along.
Joe
CH750 scratch building
On 8-May-09, at 11:52 PM, Craig Payne wrote:
<craig(at)craigandjean.com>
pages of
is bent
generally
a length
2 by 4s
-- Craig
