Mike Whisky
Posted: Thu May 07, 2009 12:00 pm Post subject: AFS Manifold transducer & Lightspeed Ignition Manifold p |
Hello
I am wondering how those of you, who use the LSE Plasma ignition and the AFS Engine monitor interconnected the manifold tubes. Is there a Y-connector available that allows to root one pipe to the LSE and the other to the AF Manifold transducer from the firewall tube fitting.
Cheers
Michael
_________________ RV-10 builder (flying)
#511 |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu May 07, 2009 5:02 pm Post subject: Re: AFS Manifold transducer & Lightspeed Ignition Manifo |
I forget what the ID is on the yellow tubing that comes with the LS kit but get a barb T from Aircraft Spruce for that size. Call Rob at AFS and they can send you a replacement fitting for the inside of the bulkhead fitting from Vans. You then use the yellow tubing from the bulkhead to the T and from the T to the LS. The use another short piece from the T perhaps 1/2" and push it inside some tygon tubing. You will use something like the 1/8" ID tygon tubing and slip it over the yellow tubing and together push it onto the 3rd T fitting. The other end goes to the AFS manafold transducer.
Hope the attached picture helps.
102.96 KB |
2846 Time(s) |
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Mike Whisky
Posted: Fri May 08, 2009 1:44 pm Post subject: Re: AFS Manifold transducer & Lightspeed Ignition Manifo |
Thank you Gary that helped a lot.
Michael
DO NOT ARCHIVE
#511 |
