maurice609(at)live.com Guest
Posted: Mon May 04, 2009 2:26 pm Post subject: fairings |
Hi:
I am now installing the Wheels fairings C fitting them...the question I have is how to hold them
the top and the ones for the main wheels.
I would appreciate pictures and ideas on the subject. I though nut plates C that is no good C only
machine screws?
It must be and easy way to do this C well we know nothing is easy..
thanks
maurice
rv6a
Hotmail® has a new way to see what's up with your friends. Check it out. [quote][b]
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
bill(at)repucci.com Guest
Posted: Mon May 04, 2009 3:33 pm Post subject: fairings |
Maurice,
The best place for these types of answers is on the www.vansairforce.net forum.
To answer your question:
<![if !supportLists]>1. <![endif]>Get the two halves to mate up. Just cleco them together for now.
<![if !supportLists]>2. <![endif]>Enlarge the wheel opening and carve them up so they fit over the wheel and gear leg.
<![if !supportLists]>3. <![endif]>Mark on the brackets were your screws are going to go with your Sharpe
<![if !supportLists]>4. <![endif]>Duck taped some wood blocks on top of the wheels to give them the proper height.
<![if !supportLists]>5. <![endif]>Get them lined up. (You may have to enlarge the wheel and gear leg holes.)
<![if !supportLists]>6. <![endif]>Drill through the wheel pants and brackets where your marks are.
<![if !supportLists]>7. <![endif]>Install platenutes as needed. (I think machine screws will come out.)
<![if !supportLists]>8. <![endif]>Once you have them positioned correctly, enlarge the wheel opening. (Search the Vansairforce.net forum on this, there is a good reason to have the opening larger than you think is necessary.)
<![if !supportLists]>9. <![endif]>Add plate nuts to the wheel pants to attach the front half.
FYI – This is all detailed on the Orndorff videos. (Well done George.) I suggest you see if you can pick up a copy.
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of maurice murillo
Sent: Monday, May 04, 2009 6:26 PM
To: rvsoutheast-list(at)matronics.com
Subject: fairings
Hi:
I am now installing the Wheels fairings, fitting them...the question I have is how to hold them
I would appreciate pictures and ideas on the subject. I though nut plates, that is no good, only
machine screws?
It must be and easy way to do this, well we know nothing is easy...
thanks
maurice
rv6a
Hotmail® has a new way to see what's up with your friends. Check it out. | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 0123456789
Posted: Tue May 05, 2009 2:34 pm Post subject: fairings |
Bill:
Thanks for the info. I look in the web page you mentioned i did not find what i needed. I wish i remember
the name of builder I was looking one time. he had photos of all this.
I already have the wheel pants C installed C I have been flying with them for months C but never did
finished the fairings... now they are finished not painted yet. so is a questions how to hold them
in place
maurice
rv6a
Subject: RE: fairings
Date: Mon C 4 May 2009 19:32:04 -0400
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass p.EC_MsoListParagraph C .ExternalClass li.EC_MsoListParagraph C .ExternalClass div.EC_MsoListParagraph {margin-right:0in;margin-bottom:0in;margin-left:.5in;margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass span.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.EC_EmailStyle21 {font-family:'Calibri' C'sans-serif';color:#1F497D;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;} .ExternalClass ol {margin-bottom:0in;} .ExternalClass ul {margin-bottom:0in;}
Maurice C
1. Get the two halves to mate up. Just cleco them together for now.
2. Enlarge the wheel opening and carve them up so they fit over the wheel and gear leg.
3. Mark on the brackets were your screws are going to go with your Sharpe
4. Duck taped some wood blocks on top of the wheels to give them the proper height.
5. Get them lined up. (You may have to enlarge the wheel and gear leg holes.)
6. Drill through the wheel pants and brackets where your marks are.
7. Install platenutes as needed. (I think machine screws will come out.)
8. Once you have them positioned correctly C enlarge the wheel opening. (Search the Vansairforce.net forum on this C there is a good reason to have the opening larger than you think is necessary.)
9. Add plate nuts to the wheel pants to attach the front half.
Sent: Monday C May 04 C 2009 6:26 PM
Subject: RVSouthEast-List: fairings
Hi:
machine screws?
It must be and easy way to do this C well we know nothing is easy...
thanks
maurice
rv6a
0Windows Live™: Keep your life in sync. Check it out. [quote][b]
tadsargent(at)bellsouth.n Guest
Posted: Tue May 05, 2009 4:12 pm Post subject: fairings |
Try WWW.RVProject.com
Tad sargent
Date: Tuesday, May 5, 2009, 6:30 PM
#yiv1236763253 .hmmessage P
margin:0px;padding:0px;}
#yiv1236763253 {
font-size:10pt;font-family:Verdana;}
Bill:
Â
Posted: Tue May 05, 2009 4:28 pm Post subject: fairings |
I can’t help you as my -9 is a tail dragger.
Bill (Who needs to re-make his upper intersection fairings as the RV-7 fairings didn’t work so well and no one makes them for a -9.)
Sent: Tuesday, May 05, 2009 6:31 PM
Bill:
I already have the wheel pants, installed, I have been flying with them for months, but never did
in place
maurice
rv6a
Date: Mon, 4 May 2009 19:32:04 -0400
Maurice,
8. Once you have them positioned correctly, enlarge the wheel opening. (Search the Vansairforce.net forum on this, there is a good reason to have the opening larger than you think is necessary.)
Subject: fairings
Hi:
machine screws?
thanks
maurice
rv6a
Hotmail® has a new way to see what's up with your friends. Check it out. | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution List">http://www.matronics.com/Navigator?RVSouthEast-Listronics.com | 01
Windows Live™: Keep your life in sync. Check it out. 23456789 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 0 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 1 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 2 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 3 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 4 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 5 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 6 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 7 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 8 | Quote: | | http://www.matronics.com/Navigator?RVSouthEast-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1
Larry Bowen
Posted: Tue May 05, 2009 4:34 pm Post subject: fairings |
Screws and tinnerman washers are often used. Sam used springs on the upper
ones (although his are made from AL):
http://home.hiwaay.net/~sbuc/journal/finish5.html
Lots of options.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Sent from Welcome, NC, United States
On Tue, May 5, 2009 at 8:27 PM, Bill Repucci <bill(at)repucci.com> wrote:
[quote] I can’t help you as my -9 is a tail dragger.
*From:* owner-rvsoutheast-list-server(at)matronics.com [mailto:
owner-rvsoutheast-list-server(at)matronics.com] *On Behalf Of *maurice
murillo
*Sent:* Tuesday, May 05, 2009 6:31 PM
*To:* rvsoutheast-list(at)matronics.com
*Subject:* RE: fairings
Bill:
Thanks for the info.* I look in the web page you mentioned i did not find
what i needed. I wish i remember*
*the name of builder I was looking one time. he had photos of all this.*
*I already have the wheel pants, installed, I have been flying with them
for months, but never did*
*finished the fairings... now they are finished not painted yet. so is a
questions how to hold them *
*in place*
*maurice*
*rv6a*
Maurice,
The best place for these types of answers is on the www.vansairforce.netforum.
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Larry Bowen
Posted: Tue May 05, 2009 4:37 pm Post subject: fairings |
I used screws -- I had the rectangular gear. Same idea as our round gear.
http://blog.bowenaero.com/?p=19
Larry Bowen
murillo
Bill:
*in place*
*maurice*
*rv6a*
Maurice,
RV-8 SOLD,
