Extra holes in wing ribs???
william(at)gbta.net
PostPosted: Tue May 05, 2009 4:19 pm    Post subject: Extra holes in wing ribs??? Reply with quote
Somehow in match drilling the left rear spar to the wing ribs I got two extra holes in the trailing edge flange (flange that rivets to the rear spar) of the #'s 3 and 4 ribs. They are holes that were there originally if I remember right. However, the holes that I match drilled to the rear spar were a little bit further from center than the original holes. Pictures are attached. Anyhow, if it's a mistake it's already made. How do I fix it or should I go on and not worry about it. If I drill the holes to the rear spar and rivet them I think it will be too close to the W-1007B rear spar reinforcement fork (it's going to be right on the edge).
Bill
 Filesize:  436.82 KB
 Viewed:  1357 Time(s)
Strasnuts
PostPosted: Tue May 05, 2009 8:18 pm    Post subject: Extra holes in wing ribs??? Reply with quote
Van's keep production cheaper by making all of the ribs the same. Those extra holes are just not used. It is the difference between the regular rib holes and the gap seal holes(I believe, it's been a month since I did that.)
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
