jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon May 04, 2009 4:04 am Post subject: Fuel Tank Rivet Leaking |
We noticed a few leaking rivets on the top of the fuel tanks in the first two inboard rows of rivets. Rivets were leaking on both wings, two rivets on the left wing, one rivet on the right wing. These are quickbuild wings......
We called Vans for advice on how they would like us to proceed for a fix. They asked us to apply green wicking Loctite to the faulty rivets. We applied the Loctite, and will file a PIREP when the results come in. My question to the group is, has anyone else used this repair method? Was it a temporary repair, or a long term fix (I understand we don't have a old fleet to prove this). Is this common in the industry?
I have my own opinions of what Vans should do to solve our problem (new tanks), but we will try it their way first.....
Thanks, Jason Kreidler
It runs, weight and balance complete, transition training done, doing minor finishing and calibrations, waiting on paperwork.
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner [quote][b]
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
pietflyr(at)bellsouth.net Guest
Posted: Mon May 04, 2009 4:33 am Post subject: Fuel Tank Rivet Leaking |
Jason, I would be interested in hearing your results. I’ve got a 22 year-old RV-4 that is leaking at several rivets. This was built using the old Pro-Seal that Van’s has since moved away from due to its becoming brittle and cracking after 20 years. I would like to see if this fix works. When I contacted Van’s about my RV-4, their only solution was to build new fuel tanks. Where did you buy this green, wicking Loctite?
Jack Phillips
RV-10 #40610
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com
Sent: Monday, May 04, 2009 8:01 AM
Subject: Fuel Tank Rivet Leaking
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
johngoodman
Posted: Mon May 04, 2009 4:59 am Post subject: Re: Fuel Tank Rivet Leaking |
Loctite 290 Threadlocker. Available at Amazon and many auto supply places. It's about $20 for a tiny tube, so don't waste it.
John
14.72 KB |
14842 Time(s) |
_________________ #40572 Phase One complete in 2011 |
Posted: Mon May 04, 2009 5:00 am Post subject: Fuel Tank Rivet Leaking |
It's interesting that when Van's gets a call about a quickbuild wing that is leaking, they recommend the loctite method. When they get a call about a customer-built wing that is leaking, they say the only option is to either get into the tank and fix it or build a new tank. I have personal experience with this inconsistency. Sounds to me like a little bit of a double standard.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On May 4, 2009, at 8:00 AM, jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com) wrote:
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
| [b]
jkreidler
Posted: Mon May 04, 2009 5:12 am Post subject: Fuel Tank Rivet Leaking |
We used "Napa 290", purchased at our local Napa store (obviously).
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
ScooterF15
Posted: Mon May 04, 2009 5:21 am Post subject: Fuel Tank Rivet Leaking |
I used this method on a single leaking rivet on a QB wing tank. I had a hard time getting it to work. Someone recommended putting a slight vacuum on the tank to get the Loctite 390 to get pulled in around the rivet. That is hard to do with an installed tank. I used a ballon taped to the end of a short piece of rubber hose to put some air pressure on the outside of the rivet. I also used a heat gun on the area while the Loctite was still wet. It sealed the leak and it has been leak free for 1.5 years now.
-Jim
N312JE
On Mon, May 4, 2009 at 7:00 AM, <jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)> wrote:
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
get="_blank">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com
| [b]
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Mon May 04, 2009 5:44 am Post subject: Fuel Tank Rivet Leaking |
Could this stuff be used before paint.... or could something else be used before paint
It would be nice to solve the problem before it becomes a problem.
Don
--- On Mon, 5/4/09, jason.kreidler(at)regalbeloit.com <jason.kreidler(at)regalbeloit.com> wrote:
From: jason.kreidler(at)regalbeloit.com <jason.kreidler(at)regalbeloit.com>
Subject: Re: Fuel Tank Rivet Leaking
Date: Monday, May 4, 2009, 6:04 AM
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
_________________ Don A. McDonald
40636 |
coop85(at)verizon.net Guest
Posted: Mon May 04, 2009 12:53 pm Post subject: Fuel Tank Rivet Leaking |
Jason,
I had 2 rivets leaking very slightly on my QB wings. So slightly that it wasn't apparent until after the paint job, a very unpleasant surprise. Anyway, I used the green Loctite trick and it appears to have worked great. It took a number of aplications over time, but I haven't had a leak in months and am ready to repaint the area once I get the opportunity.
Good Luck,
Marcus
40276
| Quote: | From: jason.kreidler(at)regalbeloit.com <jason.kreidler(at)regalbeloit.com>
Date: Monday, May 4, 2009, 8:00 AM
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
flysrv10(at)gmail.com Guest
Posted: Mon May 04, 2009 1:48 pm Post subject: Fuel Tank Rivet Leaking |
I used their method and it worked. The stuff does not dry on top of
the rivet and is misleading. However, my fix has lasted three years.
On Mon, May 4, 2009 at 8:00 AM, <jason.kreidler(at)regalbeloit.com> wrote:
wings......
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
Rob Kermanj
wayne.e(at)grandecom.net Guest
Posted: Tue May 05, 2009 4:09 am Post subject: Fuel Tank Rivet Leaking |
Hello Jason,
I had the same problem twice, also with quick build wings. I also called Vans and told them about the problem, I was talking to Gus, who normally was really good at answers, and after our conversation that this is quick build and by theory should be better than what I could do, his answer in a back handed way was " Ya and what do you want me to do about it" His attitude really turned me off and I told him if you don't know what to do there's no sense in me talking to you and I hung up on him, which I would never normally do but his attitude was so flipped it ticked me off.
By the way he told me the same answer as he did you but but I was just telling him that in inspecting the inside of the tank, I drained it, that I could see that his hired help in the Philippines were only putting a very small amount of pro seal in the tank in order to save money. I'm assuming they're paid so much a unit and if you skimp you save money, I guess. I was trying to tell Gus that he needs to tell them to do a better job and stop cutting corners.
I actually drilled out the leaking rivets and put in cherry max rivets with a lot of pro seal on the back side of the rivet. That was two years ago and I've not had any additional leaks. When I had the leaks the plane hadn't yet been painted so drilling out the rivet wasn't a paint issue.
Wayne Edgerton N602WT
Time: 05:04:49 AM PST US Subject: Fuel Tank Rivet Leaking From: jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)
wings......
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
rene(at)felker.com Guest
Posted: Tue May 05, 2009 4:55 am Post subject: Fuel Tank Rivet Leaking |
I also have one leaky rivet on the top of the tank in the “walk area”. But, so does 410RV. I did my transition training in that aircraft and it has several leakers. I think it must have something to do with the doublers. My leaky rivet is under the 3m non-skid in the walk area and only shows up when the tank is full, so I have decided to live with it until this summer. When it gets real hot, I will try to pull the 3m stuff up and seal the rivet.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Tuesday, May 05, 2009 6:05 AM
Hello Jason,
Time:
05:04:49 AM PST US
Subject:
wings......
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
Tim Olson
Posted: Tue May 05, 2009 5:34 am Post subject: Fuel Tank Rivet Leaking |
Going back to that prior discussion about fuel tanks
I remember someone said they hadn't heard much about
any QB tanks leaking, and that it was rare. I would
like to point out that this thread has shown the reason
that my personal opinion leans towards building my
own tanks. It hasn't been very publicized before in
this amount on the list, but I've talked to many many
RV-10 builders with QB tanks that have had these problems.
I know, repetition on riveting wings isn't fun, but they
build fast, and when you're done you will know that you
did a good job prosealing. I don't understand WHY the
QB tanks seem to have such an issue....my only guess is
that to save costs they go as light on sealant as
possible. It's a common enough problem though that I
really think the company should re-evaluate the instruction
given to the offshore builders and encourage a little
more attention paid to making the tanks leak free.
The sad part is, for many builders they want to paint
before flying. I liked it that way, myself. But giving
your tanks a chance to be thoroughly leak tested may
be a good reason to delay painting on at least the wings
of your QB kit, if you're trying to choose when to paint.
Luckily most rivet leaks will be on the bottom side
of the wing.
It would be interesting to take a tally of how many QB
wings came with leaks, and then forward the numbers
to Van's. Perhaps they don't have a clue the number is
so high, but compiling it here may provide incentive to
them to do a bit more training over there.
Tim Olson - RV-10 N104CD
Posted: Tue May 05, 2009 5:54 am Post subject: Fuel Tank Rivet Leaking |
One point of clarification………I built my own tanks.
Tim, I think it would be a good idea to get a list of quick build leakers….but don’t count me in, I did this to myself. J
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: Tuesday, May 05, 2009 6:55 AM
Subject: RE: Fuel Tank Rivet Leaking
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Hello Jason,
Time:
05:04:49 AM PST US
Subject:
wings......
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
| Quote: | | http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution | 01234567890123456789
dlm46007(at)cox.net Guest
Posted: Tue May 05, 2009 5:58 am Post subject: Fuel Tank Rivet Leaking |
No quick build wing leaks here after 140 hours. Mine were shipped to me
3/2005. My QB wings were among the first batch produced. I also did not
follow the plans to remove and test the tanks. I thought that just another
way to create a leak where none may exist. The tanks were supposedly tested
at the build factory.
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue May 05, 2009 9:35 am Post subject: Fuel Tank Rivet Leaking |
85 hours on my QB wings and no leaks at this time. Wings delivered in
June 2006. I did take the tanks off and test them per Van's
instructions. I also had a self-induced leak when I accidentally
dropped the tank from the wing cradle and bent the leading edge and
inboard tank rib.
THAT was one of those real bad moments in building this airplane!
David Maib
40559
Flying
another
tested
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
jkreidler
Posted: Tue May 05, 2009 12:51 pm Post subject: Re: Fuel Tank Rivet Leaking |
The good news is we found the leaks before paint, as we intend to fly off Phase 1 without paint.
The RV-10 trainer in Texas also has leaking rivets on top of the wing, in the wing walk area.
It would be interesting to note the location of all of the leaks found so far. I suspect that the last inboard rivets at the end of the wing walk stiffeners (T-1011) is where most leaks are occurring. This looks like it is a highly stressed rivet joint. I think it might be good practice to not use this section of the wing as a walking area. I may be wrong....
Thanks or 'tanks' for all the replies!
Jason Kreidler #40617 - 4 Partner Build
Do Not Archieve
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Thu May 07, 2009 4:56 am Post subject: Fuel Tank Rivet Leaking |
My opinion on this is that, like everything else, $$ drives a fix or lack thereof. As long as Van's isn't incurring additional costs in support, PR, or hard dollars, there is no incentive to deal with it. This is the same as the nose wheel and other issues. The first time someone contacts VISA and requests a charge reversal because of a defective product that the vendor won't fix they $might$ look at addressing the problem. Or they might fix the problem by withholding any future sales to the individual leaving them with a worthless partial kit.
My $0.02
Michael
