cjhukill(at)cox.net Guest
Posted: Sun May 03, 2009 1:40 pm Post subject: Door Straps |
I am working on the cabin doors and would like to install some reinforcements and nutplates in the doors to attach door straps to. I would like some suggestions as to where on the door the straps should attach to be easily reached and used to hold onto with the door cracked while taxing for ventilation. Not having an airplane to sit in to determine where a good location on the door would be that would allow for a comfortable reach and yet be out of the way when not in use, I am soliciting ideas and pictures.
Chris (I can't believe people would build an entire airplane out of this miserable fiberglass) Hukill
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Sun May 03, 2009 4:10 pm Post subject: Door Straps |
I did this without the need for reinforcing the door. Looked all over for a decent strap.... then found these for $2.98 at $9.98 store in Roseville, CA. Can get them for you if you'd like. Slight modification to the strap and then paid to have a handle sewed. Works great, looks pretty good to.
Don McDonald
Flirst flight scheduled tentatively for this Friday.
--- On Sun, 5/3/09, Chris Hukill <cjhukill(at)cox.net> wrote:
Subject: Door Straps
Date: Sunday, May 3, 2009, 2:19 PM
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
352.42 KB |
1916 Time(s) |
211.58 KB |
1916 Time(s) |
129.58 KB |
1916 Time(s) |
_________________ Don A. McDonald
40636 |
