Need some help with the ignition switch
john.marzulli(at)gmail.co
PostPosted: Fri May 01, 2009 3:41 pm    Post subject: Need some help with the ignition switch Reply with quote
I am using the ignition switch supplied by Zenith, sources from ACS.
Playing with it I wanted to do a quick hookup to a small 12V lantern battery and confirm how it is supposed to work using a multimeter. Using the diagram I hooked up some wires using test clips.
What I found was that the start position worked as it should. When the ignition was set to "BOTH", "LEFT" or "RIGHT" I failed to see any current flow off the wires towards where the P-Leads should be.
From the left and right leads I returned the current back to the battery.
Am I:
1) wrong to close the circuit off the left and right ignition leads for my test scenario?
2) Should I actually expect to see power on the left or right leads in my scenario?
Thanks in advance!
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
craig(at)craigandjean.com
PostPosted: Fri May 01, 2009 3:49 pm    Post subject: Need some help with the ignition switch Reply with quote
A magneto switch doesn’t feed power to the mags through the P-leads. It only grounds them to kill one or both mags.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of John Marzulli
Sent: Friday, May 01, 2009 5:37 PM
Subject: Need some help with the ignition switch
Am I:
Thanks in advance!
John Marzulli
dougsnash
PostPosted: Fri May 01, 2009 4:01 pm    Post subject: Need some help with the ignition switch Reply with quote
John, most aircraft ignition switches ground the ignition to shut the engine down. In off, both P-Leads are grounded. In the right poistion, the left P-Lead is grounded, in the left position, the right P-Lead will be shorted to ground. You should not power this switch at all. Even the start terminal should be a path for the solenoid coil voltage to ground.
Hope this helps
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
Final Assembly
Received: Friday, May 1, 2009, 6:37 PM
from ACS.
12V lantern battery
Using the diagram
should. When the
Am I:
test scenario?
right leads in my
scenario?
Thanks in advance!
John Marzulli
__________________________________________________________________
Looking for the perfect gift? Give the gift of Flickr!
http://www.flickr.com/gift/
PostPosted: Fri May 01, 2009 4:02 pm    Post subject: Need some help with the ignition switch Reply with quote
Here is some more information: The common off-left-right-both-start switch from Aircraft Spruce has two terminals on it labeled “GRD”. The shields on the p-leads connect to the GRD terminal in the center of the switch. I’ve attached a snippet from diagram Z-27 in the AeroElectric update on page 36 at the link below. The table shows what actually happens inside the switch.
https://matronics.com/aeroelectric/R12A/AppZ_12A3.pdf
-- Craig
Am I:
Thanks in advance!
John Marzulli
 Filesize:  70.18 KB
 Viewed:  3490 Time(s)
PostPosted: Fri May 01, 2009 5:08 pm    Post subject: Need some help with the ignition switch Reply with quote
That clears it up!
I was under the impression that power was flowing out of the switch to the p-leads closing a solenoid on them ( or something else ). It makes much more sense that power is flowing out of the mags to the P-Leads.
John Marzulli
On Fri, May 1, 2009 at 4:58 PM, Craig Payne <craig(at)craigandjean.com (craig(at)craigandjean.com)> wrote:
-- Craig
From: owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com) [mailto:owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com)] On Behalf Of John Marzulli
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Am I:
Thanks in advance!
John Marzulli
