ixb(at)videotron.ca Guest
Posted: Fri May 01, 2009 5:24 am Post subject: Fried EXP2BUS was EXP2BUS and non-functioning alternator |
Yes.
On Fri, 2009-05-01 at 01:03 -0400, Mike Humphrey wrote:
Ian,
Did you install a 40amp breaker per the instructions between the alternator
and the EXP2bus? The Master breaker is only designed for 35amp on the
board.
Mike H
Posted: Fri May 01, 2009 5:42 am Post subject: Fried EXP2BUS was EXP2BUS and non-functioning alternator |
Thanks Ed. I'll check for any signs of high current. I was able to
check the power at the alternator and the 12V is getting to the right
pin, the warning lamp lead is connected to the right place (and showing
about 1V, not sure if that's what you would expect to see the other side
of a 12V LED) but it "felt right".
Your fellow RVer probably read the bit in the EXP2BUS about removing the
on-board relay if he planned to go above 40 amps, but you have to
replace it with an external relay. In the end I did install an external
relay, so I jumpered the connectors on the board per the installation
instructions from the EXP2BUS people.
| Quote: | From what you are saying, I should be able to see charging current. Do
you folks normally see a high current after starting. I'm only seeing
about two amps, and not sure if I should expect to see a lot more, when
the partially recharged battery is at about 12.0V.
Ian
On Thu, 2009-04-30 at 18:48 -0400, Ed Anderson wrote:
Hi Ian,
While I do not have an EXP2bus, I did assist a fellow RVer who had one that
was giving him problems. The problem was the battery would not stay
charged, charge it up and over night it would be dead.
I had no experience with the EXP2bus, but did have a voltohm meter and got
the schematics off the internet. To make a long story short, at some point
someone had blown/cooked the Exp2 on-board 40 amp (Master) relay. More on
how I think they did it - which is my real reason for addressing your
question.
When I first pulled the board I noticed that the solder coating on some of
the copper traces on the board had gotten hot enough to melt and run off - a
sure sign of excessive current flow. I then found that the master on-board
relay was missing from its socket and a heavy strip of copper bar had been
solder across two of the relays socket pins.
The addition of this jumper strip in lieu of the relay resulted in the
battery remaining connected to the alternator B lead (and other board loads)
even with the master switch off. The reason is that when the board's master
switch is on all it does is ground the circuit through this relay and causes
it to close (or open if switch is off).
So with no relay and the jumper installed, there was no way to disconnect
the load drain on the battery which as a consequence was drained overnight.
I looking over the EXP2 diagram it became clear that IF the board's master
switch was left ON AND the "B" lead of the alternator was grounded (or the
alternator somehow shorted out) that the path of current went from battery
through board (melting the solder from the traces), through the relay
(frying the 40 amp relay) and on to ground through the "B" lead. Now, I was
not there, so don't know if this happened, but it certainly would fry the
board if it did.
So make certain that if you work on the board or alternator to disconnect
the battery OR at a minimum insure the Master switch is OFF.
Now, I don't know if your board has a problem, but if I had and Exp2 board
and my battery was not charging I would check the on-board relay.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://www.flyrotary.com/
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm
Ed Anderson
Posted: Fri May 01, 2009 3:35 pm Post subject: Fried EXP2BUS was EXP2BUS and non-functioning alternator |
Ok Ian,
Yes, you can remove and jump the relay positions provided you are using the
jumper provided by the EXP2 manufacture for that purpose. Jumping it with a
wire (as in the case I mentioned) simply will not work. I believe the
proper jumper has a diode in the circuit to prevent the battery from
draining back through the generator.
Good luck, that's all I can offer.
Ed
Ed Anderson
Matthews, NC
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
