dballin
Posted: Sat May 02, 2009 7:20 am Post subject: Grounding Batteries |
I am working on a Lancair Legacy (ie carbon frame) and basically the Z-14 system 24v with two batteries. The main will have a larger battery and 60A alt, the aux with a smaller B&C battery and an SD20. The batteries will be behind the seats with the power grid contactors. My plan is to run a large ground to the engine/starter for the main (4AWG) and a 10AWG for the aux to a ground stud on the firewall (which then gets connect to the engine case). So here is my question. I want to have a local ground back by the batteries for both main and aux components. Should I have a separate ground bus for each battery? or can I attach both neg terminals to a single ground bus. It seems to me that this does add some redundancy to the ground path, but it also will hide any failure in the ground leads. Thoughts?
Dan Ballin LEG2 #286
mrspudandcompany(at)veriz Guest
Posted: Sat May 02, 2009 8:22 am Post subject: Grounding Batteries |
Dan Ballin LEG2 #286 [quote] Dan, You said you are running a 24V system. Are you using 2 - 24V batteries or 2 – 12V batteries? If using 2 – 12V then they will be in series for the 24V system, meaning that the Neg. terminal of one battery will be at ground and the pos terminal of that battery will attach to the neg terminal of the second battery, and the pos of the second battery will be your 24V supply. If you are using 2 – 24V batteries, then the neg terminals of the two batteries can be attached together and to ground, and the pos terminals will give you 2 independent 24V sources. Roger [b]
Posted: Sat May 02, 2009 10:57 am Post subject: Grounding Batteries |
At 10:17 AM 5/2/2009, you wrote:
| Quote: | I am working on a Lancair Legacy (ie carbon frame) and basically the
leads. Thoughts?
Ground wires can and should be crafted with
the robust-as-hell philosophy in mind. I.e.,
as reliable as prop bolts. This means take some
extra care in crafting the conductors, routing
for mechanical isolation from risks and bolting
things together with metal lock nuts or LockTite
on threads.
One conductor from crankcase to firewall ground
stud. One conductor from firewall ground to a battery
ground behind seats (small forest of tabs or perhaps
just a stud on which all rear grounds mount). Two
conductors from rear ground location to each of the
(-) terminals of the batteries. You might want to
consider 2AWG welding cable for the fat ground
wires . . . MUCH more pleasant to work with than
22759.
( -Thomas Paine 1776- )
