Switch
mhilderbrand
PostPosted: Fri May 01, 2009 1:08 pm    Post subject: Switch Reply with quote
Hi everyone,
I bought a handful of 1-2 switches for various items i.e., landing lights, strobes, left & right mag, etc. My question is can I use the same switch for the master and alternator? Looks like sometimes people are using the 2-3 and only having one switch - being multifunctional. Since I now have a small surplus of 1-2 switches, I thought I might just use them instead. This will be on the Jab 3300 engine. As you can tell I am ignorant to this area... but I am trying to learn! Thanks!
Michael Hilderbrand
Derby, Kansas
Http://www.kansasflying.com
PostPosted: Sat May 02, 2009 5:24 am    Post subject: Switch Reply with quote
At 04:05 PM 5/1/2009, you wrote:
Hi everyone,
The first batteries to go into aircraft were
charged by generators. Unlike many if not
most alternators, generators would come on line
and run by themselves as a useful power source.
It was common and practical to control the
generator and battery with their own separate
switches.
When alternators began to replace generators
in the 60s . . . we found that product of the
day was best operated with a battery on line.
This insured that (1) the alternator would have
excitation power available to go to work and
(2) there was a battery always available to
avoid stalling a self-excited alternator when
hit with a hi-inrush load (like landing gear
motors and/or landing lights).
Hence the development of the infamous "split-
rocker" master switch for single engine light
aircraft.
[img]cid:.0[/img]
This product's rockers were mechanically interlocked
to prevent an alternator from being on line
without a battery . . . yet allows the battery
to be on without the alternator.
This functionality is emulated by the use of the
progressive transfer 2-10 style switch. Alternatively,
some Z-figures show a 2-3 that brings the battery
and alternator ON and OFF together. This is okay
too as long as you have a means by which the
externally excited alternator can be shut OFF for
ground maintenance activities.
In the case of Z-13/8 I suggest a 2-3 switch
when paired with the crowbar ov protection that
calls for a pullable circuit breaker co-located
with the DC POWER MASTER switch. In the switch
panel options drawing at . . .
http://www.aeroelectric.com/PPS/Switch_Panels/spanel.pdf
. . . all configurations illustrated show a 2-3
DC PWR MASTER and a 5A pullable breaker. In this
drawing . . .
http://www.aeroelectric.com/PPS/Switch_Panels/Switches.pdf
. . . the 2-10 switch is suggested for a DC PWR
MASTER. The pullable breaker allows for disabling
the alternator for extended ground operations of
the electrical system with the engine not running.
You can certainly used independent switches to
control the battery and alternator. However, it
is incumbent upon you to understand the limitations
of the equipment items you've installed and to
educate yourself (and anyone else who might fly
your airplane) as to the proper operation of those
switches consistent with those limitations.
( -Thomas Paine 1776- )
 Filesize:  131.54 KB
 Viewed:  2943 Time(s)
