High tension insulated rod
wise(at)txc.net.au
PostPosted: Wed Apr 29, 2009 8:09 pm    Post subject: High tension insulated rod Reply with quote
G'Day,
Does anyone have any spare magneto high tension insulated rods for sale for M14P?
This is the high tension lead the goes from the mag to the mag cap.
We have one mag US due to the insulation breakdown. Have made a new lead with high tension wire, folded the wire over a small washer and soldered.
Am yet to try it.
If have part, please advise price and approx express post to Australia.
Thanks and cheers,
Chris
mark.bitterlich(at)navy.m
PostPosted: Thu Apr 30, 2009 8:49 am    Post subject: High tension insulated rod Reply with quote
Doug Sapp has them.
Mark Bitterlich
smime.p7s
 Filename:  smime.p7s
 Filesize:  4.81 KB
 Downloaded:  503 Time(s)
dougsappllc(at)gmail.com
PostPosted: Thu Apr 30, 2009 9:43 am    Post subject: High tension insulated rod Reply with quote
Thank's Mark but  I just sent my last 3 HT rods to a customer in Belgium.  I do have some inbound but we are looking at 30 days.  I'll check to see if I can get some additional stock sent via Fed Ex.
Doug
On Thu, Apr 30, 2009 at 9:48 AM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]Doug Sapp has them.
Mark Bitterlich
ronwasson
PostPosted: Thu Apr 30, 2009 10:38 am    Post subject: High tension insulated rod Reply with quote
I need one too doug
ron wasson
On Apr 30, 2009, at 12:40 PM, doug sapp wrote:
[quote]Thank's Mark but I just sent my last 3 HT rods to a customer in Belgium. I do have some inbound but we are looking at 30 days. I'll check to see if I can get some additional stock sent via Fed Ex.
Doug
Mark Bitterlich
alikatz(at)mbay.net
PostPosted: Thu Apr 30, 2009 3:38 pm    Post subject: High tension insulated rod Reply with quote
Doug,
I have them is Stock, I'll check in the morning just how many I have left.
viperdoc(at)mindspring.co
PostPosted: Thu Apr 30, 2009 4:49 pm    Post subject: High tension insulated rod Reply with quote
Jim,
Do you have two extra ones. Had to build one of mine up with solder.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Jim Selby
Sent: Thursday, April 30, 2009 6:38 PM
To: yak-list(at)matronics.com
Subject: Re: High tension insulated rod
Doug,
----- Original Message -----
Sent: Thursday, April 30, 2009 10:40 AM
Doug
Doug Sapp has them.
Mark Bitterlich
lie.buyse(at)telenet.be
PostPosted: Sun May 03, 2009 1:47 am    Post subject: High Tension Insulated Rod Reply with quote
We zijn dus niet de eersten. Misschien toch beter het stukje ter plaatse te laten?
Nogmaals dank voor het herstellen!
