gareywittich2000(at)yahoo Guest
Posted: Wed Mar 25, 2009 9:03 pm Post subject: Filler for "Unwanted" Rivet Holes ??? |
Greetings:
What material have you Builders used to fill in a couple of unwanted holes in the Skin, where a rivet can NOT be placed to plug the hole ????
Is Super-Fil a possible solution ????
Thanks, Garey Wittich Santa Monica, CA
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
jstiegel(at)dishmail.net Guest
Posted: Mon Mar 30, 2009 7:35 am Post subject: Filler for "Unwanted" Rivet Holes ??? |
JB Weld may be a good plug. I used it to seal the forward windscreen to the alum frame then glassed it up. RV-7A tip up quick build.
On Thu, Mar 26, 2009 at 12:02 AM, Garey Wittich <gareywittich2000(at)yahoo.com (gareywittich2000(at)yahoo.com)> wrote:
[quote]--> RV7-List message posted by: Garey Wittich <gareywittich2000(at)yahoo.com (gareywittich2000(at)yahoo.com)>
Greetings:
rget="_blank">http://www.matronics.com/Navigator?RV7-List
http://forums.matronics.com
le, List Admin.
lrhelming(at)gmail.com Guest
Posted: Mon Mar 30, 2009 12:42 pm Post subject: Filler for "Unwanted" Rivet Holes ??? |
superfil will work fine. It is epoxy based. LH
On Mon, Mar 30, 2009 at 10:33 AM, JOHN STIEGELMEYER <jstiegel(at)dishmail.net (jstiegel(at)dishmail.net)> wrote:
[quote]JB Weld may be a good plug. I used it to seal the forward windscreen to the alum frame then glassed it up. RV-7A tip up quick build.
