TteamGrumman-List: Percent power. How to calculate? . . .
Discover
PostPosted: Wed Apr 29, 2009 5:10 am    Post subject: TteamGrumman-List: Percent power. How to calculate? . . . Reply with quote
You might want to use the more accurate and more current chart and recalculate your numbers. I sent it to you direct 'cause I didn't thiunk it would come thru here. I'll try and attach it now as I see that teh Fig 3-34 did come thru. This is Fig 3-35. Hoe it helps
ned
Fig_3-35.pdf
 Filename:  Fig_3-35.pdf
 Filesize:  126.21 KB
 Downloaded:  271 Time(s)
