sidsel.svein(at)oslo.onli Guest
Posted: Tue Apr 28, 2009 7:29 am Post subject: SV: Fuel valve open or close between flights |
Raimo,
I forgot to answer that question, so here it comes:
I see no reason to close the fuel valve while the aircraft is parked.
Rather to the contrary, if there is a leak downstream from the valve there
is a chance to detect it while still on the ground, by the smell.
My routine, reflected in the check list, is to switch to RESERVE before
starting the engine, and keep it there during warm-up and taxi. Reason: I
wish to flow fuel through the reserve side of the system and the filter in
that line to make sure it is not blocked, and so that any debris in the
reserve line is caught by the filter and can be inspected there (nothing
found so far in either line).
At run-up, first check is to switch to MAIN, and first check before take-off
roll is to verify that it has been switched to MAIN.
Once in a while, I switch to OFF and back on the ground just to check free
movement.
Svein
LN-SKJ
-----Opprinnelig melding-----
Fra: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] På vegne av Raimo Toivio
Sendt: 28. april 2009 16:57
Til: europa-list(at)matronics.com
Emne: Fuel valve open or close between flights
All
Sveinīs answer below gave me a new topic.
After flights do you close or not main fuel selector valve?
I have elected to keep it always open!
I understand there is an other side also.
Anyway when it is always open I never forget to open it before take offs.
I tested and it is possible to make a fast take off with closed valve.
That means EFATO situation.
To prevent jamming or seizing I move it couple of times in a year between
ON-RESERVE-CLOSED positions.
Other visions please.
Raimo OH-XRT
Posted: Tue Apr 28, 2009 10:06 am Post subject: SV: Fuel valve open or close between flights |
If it only were so well, Raimo! Nowhere close to that number of flights per
year!
Svein
"My routine, reflected in the check list, is to switch to RESERVE before
roll is to verify that it has been switched to MAIN."
So you are switching it letīs say couple of hundreds times in a year?
Maybe your Andair is good enough for that but what about a poor manīs
original selector?
I assume I would have soon a broken valve and a separated selector in my
hand!
Raimo OH-XRT
