VG generators
clint_bazzill(at)hotmail.
PostPosted: Sun Apr 26, 2009 9:17 pm    Post subject: VG generators Reply with quote
Hi all C
When testing for stall speeds C power off will not work with most Kitfox'es.  There is just not enough elevator control and it will go into mush.  Test with enough power to detect stall...  I have the vg's under stab.  Over size model IV elevator and gap seal.  The AC stalls 5 mph slower with them.  10 percent position of mc C that includes flaperons.  Did tuff test with Air Cam as chase plane. Video recorded and any position  around 10 percent would work well.  I have calibrated my airspeeds and it these numbers that I used.
These are TAS
Stall speed clean without generators.  48 mph
Stall Speed with flaps no generators 43 mph
Stall Speed with generators no flaps 43 mph
Stall Speed with generator full flaps 38 mph
I did not list these in past as temp C altitude etc were all in this data.  What I listed is a brief summary of what was done.  It's reduction in stall is just about what most VG's on AC do.
Clint
Model IV-1200
1450 hours 912-ULS
dave
PostPosted: Mon Apr 27, 2009 9:23 am    Post subject: Re: VG generators Reply with quote
Clint those are high stall speeds, what does your plane weigh ?
is it SPeed wing ?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
lcfitt(at)sbcglobal.net
PostPosted: Mon Apr 27, 2009 11:54 am    Post subject: VG generators Reply with quote
Hi Clint,
For some reason I don't follow your test procedure and the goal of the test.
Most people when trying to land short will use power off to a three point.
With this configuration, vortex generators on the wings don't drop the stall
speed significantly. Are you suggesting that to land really short, to carry
a little power to flair in order energize the elevator to stall at a slower
speed. It sounds a bit counter productive.
Is it your procedure to approach with power off, then add a bit of power
just before the flair? Busy.
It seems to me that if in order to energise the elevator you need a bit of
power, there is something wrong with the horizontal stabilizer / elevator
design or geometry, or maybe a W/B issue.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Still building
PostPosted: Mon Apr 27, 2009 12:35 pm    Post subject: VG generators Reply with quote
Hi Lowell C
That is one way to land short. But not shortest.   Watch bush pilots land.  They carry quite a bit of power C they are flying on the back side of power curve.  They touch  down and cut power.  With power off in a Kitfox C you probably will drop the airplane and be landing a lot faster.   With power off trying to land C not enough elevator C critical timing and probably a rough landing.  Got to get the airspeed slow and hold it there until touch down.
Clint
P.s. that 5 mph that you can fly does a lot.
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: VG generators
Date: Mon C 27 Apr 2009 12:53:18 -0700
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Hi Clint C
With this configuration C vortex generators on the wings don't drop the stall
speed significantly. Are you suggesting that to land really short C to carry
Is it your procedure to approach with power off C then add a bit of power
power C there is something wrong with the horizontal stabilizer / elevator
design or geometry C or maybe a W/B issue.
Lowell Fitt
Cameron Park C CA
Still building
PostPosted: Mon Apr 27, 2009 12:43 pm    Post subject: VG generators Reply with quote
For a good short field landing C you fly the aircraft as slow as possible C with power to touch down.  You adjust power to control altitude C elevator for airspeed.  Check this video out for a demo.  That extra reduction in airspeed is important.
Clint
http://www.youtube.com/watch?v=sfeMLQNe57E
Hi Clint C
Lowell Fitt
Cameron Park C CA
Still building
Fox5flyer
PostPosted: Mon Apr 27, 2009 1:19 pm    Post subject: VG generators Reply with quote
Agreed. That is some extreme short field work. Good video, however, all that wind probably helped a lot.
I learned about approaching behind the power curve a long time ago and it works. I have a short farm strip and I always (try to) land with power on, nose high, and very slow which allows a steep approach. When I chop power and retract flaps all flying is done so I need to be very close to the ground before I do it. It takes a lot of timing and practice and if I get it just right, I'm down and stopped in just a couple hundred feet. Turbulence, cross winds, etc tends to require some modifications, but most of the time it gets me in very short, even with my heavy (880lb) S5 with no VGs.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 405+ TT
- Joseph Joubert
Guy Buchanan
PostPosted: Mon Apr 27, 2009 1:53 pm    Post subject: VG generators Reply with quote
I suspect that ideal would be to land power off, but I've found it
impossible to hit the bulls eye at zero vertical velocity and at
stall. There's just way too much going on. After watching Mark and
Hal slaughter everyone at the last spot landing contest I came to the
conclusion that Clint's method was the only way it was going to
happen. My only problem with it is that it requires a very careful
assessment of gust factor. When you're pulling it in low and slow the
last thing you want is a 5-10 mph drop in head wind with the
subsequent stall. And since the stopping distance varies as the
square of the initial velocity, (assuming a constant deceleration)
Clint's right, the extra 5 mph is significant.
(38/43)^2 = 78% of the distance to stop.
(38/4Cool^2 = 63% of the distance to stop.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Mon Apr 27, 2009 3:11 pm    Post subject: VG generators Reply with quote
You got me there, Clint. I guess I am just not a bush pilot. I probably
fit in the catigory of most pilots. I am aware of the technique and likely
will try it once I am flying with the lift reserve indicator.
Lowell
Float Flyr
PostPosted: Mon Apr 27, 2009 4:05 pm    Post subject: VG generators Reply with quote
I was trained to always do complete power off (idle) landings. When I
started flying the Kitfox I also started giving a shot of power at the flare
to level things off just before touchdown. Some times I would add power and
actually fly the plane onto the water. I actually started getting angry
with myself for using the power that way. Although it is a good procedure
for "glassy water".
What I found helped me get out of what I considered to be a bad habit was to
try to make every landing as short as possible. I also started carrying a
little more speed into the flare via a little steeper angle of descent.
The extra speed gave me more control to the flare. The idea is to have the
wing stall at the precise second the floats touch the water. Most landings
I am at full elevator up at the moment of touchdown. Once down I'll release
the backpressure on the stick slightly to prevent the plane from porpoiseing
during the run out.
I have in light winds, enough wind to tell where the water was, been able to
get the plane down and off step in around 300 ft.. I once landed a super
cub on EDOs downwind (3-6kt) in around 600 ft. I was so far from the dock I
took off flew half the length of the pond and landed again close to the
dock.
True glassy water conditions usually take about a mile or so. I round out
with a bit of power on just above the trees. And basically fly the shoreline
while descending slowly with the power on in a nose high attitude. When the
floats hit the water I slowly reduce power to the point where I can maintain
a step taxi.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Mon Apr 27, 2009 7:25 pm    Post subject: VG generators Reply with quote
My plane weighs 670 lbs.  Started out at 634 C added a lot of stuff C wouldn't remove anything I put on.  Those are real numbers C not indicated air speeds.  Matches pretty close to the kitfox books.
Clint
Date: Mon C 27 Apr 2009 10:23:59 -0700
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Clint those are high stall speeds C what does your plane weigh ?
is it SPeed wing ?
Rotax Dealer C Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=241471#241471
= Archive Search & Download C 7-Day Browse C Chat C FAQ C
&g====
akflyer
PostPosted: Wed Apr 29, 2009 5:08 am    Post subject: Re: VG generators Reply with quote
We were out playing on the beach a couple days ago. The KF did a lowell approach, mine was more of a clint approach. The cross wind did not make for ideal use of full flaps, but you will get the idea.
http://www.youtube.com/watch?v=3bddee4CSqg
 Filesize:  253.97 KB
 Viewed:  10034 Time(s)
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
