vmenkal(at)mac.com Guest
Posted: Sun Apr 26, 2009 4:40 pm Post subject: Additional info on wing tip |
Found the following post when searching the archives. I have same problem with wing tip pointing down if fit is correct.
Heat gun ..... any comments?
Haven't seen the photo you mentioned, but just about everybody runs into
problems with these wingtips. I decided the main thing is to
make sure you have the tip rotated back far enough so the bottom of the
airfoil remains flat; i.e, the leading edge doesn't sag a little bit at the
end.
On the first tip I did, I got everything cocked around so the skin followed
the fiberglass leading edge perfectly, but I ended up with the wingtip
pointing down just a bit from the rest of the wing. On the next wing, I
made sure the bottom edge was flat and accepted the 1/4" gap
between the skin and the fiberglass that resulted at the nose. Filled it in
with fiberglass filler from West Marine, which works real good for such
things.
As one of the other posters mentioned, a carefully applied heat gun works
great on the fiberglass tip to flex it a little where needed.
Cpt Vic[/b]
CH701 Whitehorse Yukon
randy(at)rjhebertassoc.co Guest
Posted: Mon Apr 27, 2009 4:17 am Post subject: Additional info on wing tip |
Wow Cpt Vick
You stole this from my log book J
Randall J Hebert
Identical problem with mine
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Victor Menkal
Sent: Sunday, April 26, 2009 7:39 PM
Subject: Additional info on wing tip
end.
things.
Cpt Vic
