Venturi location - no suction
skyring
PostPosted: Sun Apr 26, 2009 1:46 am    Post subject: Venturi location - no suction Reply with quote
We have exactly no suction from the 4 inch Venturi mounted under the fuselage of our S5. You can see the location in the attached photo - just behind the Grove gear and the top lip of the venturi about in line with the bottom of the gear horizontal part.
Obviously a dead area. As it's difficult to mount such a big venturi on the side of a kitfox cowling, where it would probably work ok, we're wondering what others have done? Drop it further into the airstream in the same location?
kerry
Kitfox S5 912S and loving every minute of it.
 Filesize:  650.77 KB
 Viewed:  8386 Time(s)
7suds(at)Chartermi.net
PostPosted: Sun Apr 26, 2009 2:48 am    Post subject: Venturi location - no suction Reply with quote
Kerry,
I have seen one mounted on a 4 just under the door on the fuselage.
Lloyd Cudnohufsky
Model 5 912ul
IVO IFA
skyring
PostPosted: Sun Apr 26, 2009 7:16 am    Post subject: Re: Venturi location - no suction Reply with quote
Thanks Lloyd. Would that be under the pilot's side door? Just trying to figure out where the best blast from the prop would be. Kerry.
ps to everyone. sorry about the size of that photo.
jcorner(at)shaw.ca
PostPosted: Sun Apr 26, 2009 7:51 am    Post subject: Venturi location - no suction Reply with quote
Mounted mine here, no problems and it works great
Jim
Jim Corner
Model 2, 582,. Ivo med !FA, 1100 hrs
Model 5 0-235 45hrs
Calgary, AB
 Filesize:  309.77 KB
 Viewed:  8361 Time(s)
skyring
PostPosted: Sun Apr 26, 2009 8:34 am    Post subject: Re: Venturi location - no suction Reply with quote
Jim that's a great help. Thanks. But I'm presuming you have to disconnect the hose every time you take the bottom cowl off?
Now I'm really curious and see cuffs on your lift struts and what looks like a in-flight adjustable trim on the rudder..
Curious about your cruise speed and also - what's the tailwheel?
kerry
jcorner(at)shaw.ca
PostPosted: Sun Apr 26, 2009 5:53 pm    Post subject: Venturi location - no suction Reply with quote
On 26-Apr-09, at 10:34 AM, skyring wrote:
<kerryskyring(at)hotmail.com>
Yes I disconnect each time I remove the lower cowling... barb fitting
with inexpensive vinyl tubing
Yes I have in-flight rudder trim, normal cruise about 120 mph at
5000 ASL The tailwheel is a Matco supplied by
Kitffox LLC
kerry
http://forums.matronics.com/viewtopic.php?p 41320#241320
PostPosted: Tue Apr 28, 2009 6:14 pm    Post subject: Venturi location - no suction Reply with quote
The one I saw was under the passenger's side door, not sure if it would
matter though.
