rjdaugh
Posted: Fri Apr 24, 2009 6:53 am Post subject: Lift Reserve |
Bob,
It is a version of angle of attack, but with no moving parts. Essentially
it tells you how close you are to stall. Air speed doesn't do this. If you
are loaded heavier, you will stall at a lower speed. If you in an
accelerated condition, you will stall at a lower speed. The lift reserve
has a differential pressure gauge on your panel and when the needle is in
the green, you have lots of lift. When the needle is in the yellow, you
need to pay attention! When the needle passes the line between the yellow
and the red, you stall - or land if your wheels are inches above the
runway.
Google lift reserve.
I got mine from Kelly Meiste: kellymeiste(at)jcwifi.com
It is very simple and very sensitive. As I said, it has really changed the
way I fly.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
matronics(at)bob.brennan. Guest
Posted: Fri Apr 24, 2009 7:13 am Post subject: Lift Reserve |
Thanks Randy,
I found info at http://www.liftreserve.com/. I think I'm going to order me
one of those!
Thanks again,
bob
lcfitt(at)sbcglobal.net Guest
Posted: Fri Apr 24, 2009 7:29 am Post subject: Lift Reserve |
Randy,
I have Kelly's instrument as well, but have never used it as it came in the
mail as I was in the hospital after my airplane was destroyed. Can you tell
a bit about it's performance. I have it installed in the new project, but
it won't fly until fall or later.
Lowell
Fox5flyer Guest
Posted: Fri Apr 24, 2009 7:53 am Post subject: Lift Reserve |
Do you remember how much you paid for yours, Randy?
Deke
<rjdaugh(at)rapidnet.com>
Bob,
you
runway.
the
way I fly.
Randy
rjdaugh
Posted: Fri Apr 24, 2009 9:08 am Post subject: Lift Reserve |
Bob,
Yup, That's it!
You may want to check with Kelly. At the time I got mine, he was selling
for about one third the price they were asking.
Randy
Kitfox 5/7 912S
rjdaugh
Lowell,
I am not sure what to tell you. It works as advertised! It is very
sensitive, yet very stable. It takes a couple of flights to get it adjusted
correctly. You just change the angle where it is attached to the wing.
When you hit the line between the yellow and the red, you stall. It is that
simple. I do appreciate the analog gauge. The instruments that report with
lights or LEDs just can't give you as much info.
It doesn't take too long to get a lot of confidence in it. I have it at the
top of my panel and keep half an eye on it while landing. I have a lot of
cliffs and trees around my runway so weird air currents are common. If I
see the reserve lift dropping, I am quick to get a little throttle in there.
The biggest thing it changed in my flying was take offs. I used to keep the
speed above 65 indicated to be safe. With the lift reserve, I know how much
margin I have and can fly out at absolute Vx no matter what the conditions
are. This corrects for take off weight, density altitude, accelerated
conditions,,,... If you ever find yourself in a dive, (I haven't - at least
thus far!) you can use this to avoid a secondary stall while pulling out.
I feel that every plane should have one. It will make you a better pilot.
Randy
Kitfox 5/7 912S
rjdaugh
Deke,
It was $175. But that was a few years ago. I actually flew my friends
Highlander with the "In Air Instruments, LLC" lift reserve. I felt it was
not nearly as sensitive as Kelly's.
The research that I did on it back then indicated that patents have expired
on the design, so it is public domain technology. I hope I am right on
that.
Randy
Kitfox 5/7 912S
n85ae
Posted: Fri Apr 24, 2009 9:21 am Post subject: Re: Lift Reserve |
I have my handy dandy, poor mans bacon saver. Made from a carbon
fiber tube with a lexan background and marked at 10,20,30 degrees
about mid red is where it stalls. Power on, power off, the wing stalls
at the same angle. The little birdie on the boom has a aluminum fin.
It's fun to fly with, and taught me a lot about the plane.
I don't fly with it any more, as I discovered that aircraft feel with my
plane is just as usefull. The plane is very friendly flying, and it gives plently
of control feel feedback.
However, it cost me $0, and one hour time to make, and the parts were
stuff from the scrap box. It works very well and I can see it in my peripheral
vision very easily.
Jeff
186.23 KB |
29304 Time(s) |
Posted: Fri Apr 24, 2009 9:34 am Post subject: Lift Reserve |
Thanks - it's listed as $450 + $35 S&H. Yikes! At $175 I would have ordered
it on the spot. I will email Kelly now and post the response on the list if
I get one.
bob
n85ae
Posted: Fri Apr 24, 2009 9:41 am Post subject: Re: Lift Reserve |
I'll sell you the one in the picture above for half that, only $225 PLUS
I'll cover the shipping!
It's super sensitive, and requires no maintenance. It's dead accurate,
and works in any weather conditions. PLUS it looks cool.
Jeff
Posted: Fri Apr 24, 2009 9:52 am Post subject: Lift Reserve |
No picture attached Jeff... ??
Is it like my weather stick? I take my patented stick-and-string and hang it
from the roof gutter and it tells the weather - and it's always accurate.
If it's wet it's raining
If it moves it's windy
If it's white it's snowing
If it's bright it's sunny
If you can't see it it's night
And if it's gone it's a tornado!
peteohms
Posted: Fri Apr 24, 2009 10:24 am Post subject: Lift Reserve |
Here is a home made Lift Reserve indicator.
http://glasairproject.com/GlasairI/docs/AirsoobLRI.pdf
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
n85ae
Posted: Fri Apr 24, 2009 10:39 am Post subject: Re: Lift Reserve |
I have to say, I think these systems are grossly overrated. They all do the
same thing. The super simple one I made works just as well as even the
most sophisticated systems. It might not look like much, but you can see it
and it is absolutely accurate.
I'm not going to say that somebody shouldn't spend the money if they
want to, but the one I built is plenty easy to see all the way down to short
final, at which point I'm not worried about it anyway. The big advantage
was it was free to build.
I used to work on Grumman E-2C Hawkeye's in the Navy, and they
have a very sophisticated system tied into the planes air data computer,
however in the end even it did pretty much exactly what the boom on
the wing system does.
I've flown sailplanes, and in them a simple piece of yarn on the windscreen makes a great slip indicator. So you really don't need
something all to fancy.
Jeff
napierm(at)cisco.com Guest
Posted: Fri Apr 24, 2009 10:51 am Post subject: Lift Reserve |
For the DIYer:
http://www.ch601.org/resources/aoa/aoa.htm
The thing I don't like about the Dwyer indicator is that it is a small
needle movement and it doesn't fit in a standard hole.
The movement is a differential pressure gage. Well we use one all the
time: the airspeed indicator. So you want something that shows inches
of water column. It turns out that a very low range airspeed indicator
is ideal for this. You just need to take some Testers flat black paint
and cover up the instrument markings and then some red, yellow and green
paint to put the ranges on you are interested in. Plus maybe turn the
instrument 90 deg. so the needle movement of interest is up at the top.
But an airspeed indicator is expensive, yes?
Check this one on ebay. He has a few.
http://cgi.ebay.com/ebaymotors/NIB-2-1-4-Falcon-Metric-Airspeed-0-120-KP
H-Kilometers_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ26
439QQihZ016QQitemZ260392820130QQtcZphoto
120 kph is only 75 mph.
You can easily open just the face of this instrument with a square piece
of thin sheet steel to engage the black brass ring that holds on the
glass.
I ran the numbers for inches of water to miles per hour and got:
0.5 inches = 31.9 mph = 51.4 kph
1.0 inches = 45.1 mph = 72.6 kph
1.5 inches = 55.2 mph = 88.9 kph
2.0 inches = 63.7 mph = 102.6 kph
3.0 inches = 78.0 mph = 125.6 kph
To be sure, calibrate the meter movement by using a U tube of water
(manometer) and measure the water level difference with a ruler. It's
very easy to do just using the pitot input.
Yes, I bought a couple at this price. The model number is BK120-1A. It
comes with a little sheet that shows the test data.
http://www.taihangybc.com/theng/at-004.htm
FWIW,
Mark Napier
Fox5flyer Guest
Posted: Fri Apr 24, 2009 11:24 am Post subject: Lift Reserve |
Good one Pete. Something to do next winter.
Deke
Posted: Fri Apr 24, 2009 12:54 pm Post subject: Lift Reserve |
Randy,
Below is the reply from Kelly, along with a shout-out to you.
His kit is at http://lri.kit.googlepages.com and looks really good, at the
same price you paid for it. I'll be getting one!
Thanks again for the reference Randy,
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
From: Kelly Meiste [mailto:kellymeiste(at)jcwifi.com]
Sent: 24 April 2009 4:41 pm
To: matronics(at)bob.brennan.name
Subject: Re: Lift Reserve
Hi Bob,
Thank you for the info, glad Randy is enjoying his kit!
Here's the link to my website, not much has changed.
Price is still the same, but I've added a few more options (black gauge
overlay, and a longer tube option).
Thanks for the interest, let me know if I can answer any more questions for
you.
Best regards,
Kelly
PS. Feel free to post anything about my kit (good OR bad).
Fox5flyer Guest
Posted: Fri Apr 24, 2009 2:03 pm Post subject: Lift Reserve |
Thanks, Randy. Even my feeble brain works that out to somewhere around 260%
increase. It would be interesting to hear them justify it.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
Deke,
expired
that.
Randy
dave
CDNCH701
Joined: 26 Feb 2009 Posts: 11 Location: Winnipeg, MB Canada
Posted: Sat Apr 25, 2009 8:23 am Post subject: Lift Reserve |
Ok here is a summary of all of the info available on Lift Reserve
indicators on the net. Its all there for you to sort out!!
http://www.surpluscenter.com/item.asp?UID 07040300014143&catname=air&qty=
1&item 1-1623
http://www.ronleclerc.com/photos/panel/liftreserve-gaugefaces.pdf
http://www.ronleclerc.com/photos/panel/lri-guage6.jpg
http://www.ronleclerc.com/photos/panel/lri-guage2.jpg
http://home.hiwaay.net/~sbuc/journal/liftreserve.htm
http://lri.kit.googlepages.com/
The probes could be had from John Bolding jnbolding1(at)teleshare.net and
Scott at http://www.cooknwithgas.com/LRI.html
I purchased mine from John Bolding for $30!
http://www.ronleclerc.com/photos/panel/lri-guage5.jpg
http://www.pipcom.com/~cowcam/AOAr.htm
There is a lot of info to go through... the most expensive one you can buy
is a heated unit at http://www.liftreserve.com/ if you decide to buy one!
R.D.(Ron) Leclerc
CH701 Plans(Scrap) Builder #7-6699
Porsche Power Geared Redrive
Winnipeg, MB Canada
infow(at)mts.net
4/25/2009 11:14:29 AM
This E-Mail scanned with AVG Anti-Virus Ver: 7.5!
Randy,
good, at the same price you paid for it. I'll be getting one!
Wrightsville Pa
[mailto:kellymeiste(at)jcwifi.com] Sent: 24 April 2009 4:41 pm To:
matronics(at)bob.brennan.name Subject: Re: Lift Reserve
Hi Bob,
gauge overlay, and a longer tube option).
questions for you.
Best regards,
Kelly
